RCU Forums
-   RC Scale Boating (https://www.rcuniverse.com/forum/rc-scale-boating-103/)
-   -   Rotating Radar Mechanism? (https://www.rcuniverse.com/forum/rc-scale-boating-103/8161315-rotating-radar-mechanism.html)
khkim0102 11-18-2008 10:58 PM
Hello, Boaters!
I am working on 1/200 Trumpeter Sovremenny. I want to install a rotating radar. I know that it should use gears for the proper rpm. But I don't know how and where I should install gears, motor, battery for the morot, etc.
Could anyone give me ideas with some pictures (if available), please? It iwll be greatly appreciated.
Thank you so much for your attention.
Umi_Ryuzuki 11-19-2008 12:28 AM
RE: Rotating Radar Mechanism?
Take apart a micro servo, and remove the gear stop.
Also remove the pot and the circuit board, reassemble the servo, and
wire the motor directly to your power source.
Use a thin wire to connect the servo to your rotating radar head.
http://video.google.com/videoplay?do...G1Bw&q=sdm+tug
You can see the wire connection at the pilot house just below the radar.
If you find a servo isn't working for you, these gear motors are also available.
http://www.gizmoszone.com/shopping/storepro5/agora.cgi
caragan1970 11-19-2008 07:47 AM
Dear James,
Use this if you want:
http://www.harbormodels.com/site08/radar.html
best regards
Patrick C.
khkim0102 11-19-2008 08:40 PM
Thank you very much for your responses!
I will try what you guys said. Thank you again!
fooman2008 11-28-2008 12:15 PM
there are several micro heli's that use a small motor for the tail rotor you could try those also. And I just had another thought get one of those zip-zaps from radio shack, they have very small motors and all kinds of hop-ups, for gearing etc not too terribly expensive since I would hate to have to pay the freight for a micro servo just to tear it apart.
khkim0102 12-01-2008 12:13 AM
Hi, Fooman 2008!
Thank you very much for your response. I will try a Radio Shack, as you recommended. And then, if I don't find out that I need, maybe I should order some gears from the copany the other guys recommended.
Thank you again, everyone for your advices!
