Engle VII/C
My Feedback: (10)
IL
Engle VII/C
Hello,
Aquired an Engle VII/c kit and will begin construction as soon as I can get the upgrades that are available. So my question is what upgrades would you reccomend for this sub. I have the basic kit that Engle sellswith the TMAX tank set up. I also have a Robbe F14 Navy transmitter. Can anyone out there suggest some upgrades to improve the performance of this model. For example, speed controllers, depth controllers and whatever else may be available from Engle or anyone out there. I have built and successfully sailed the Robbe U-47 and the Robbe Type 21 dynamic dive subs. Thanks. LG
NY
RE: Engle VII/C
engel stuff is usually very straight fwd. If you build it as described you will find yourself very happy. Worry about tweakin with it till after you have played with it for a few months
My Feedback: (10)
IL
RE: Engle VII/C
Question out there.......
On my Engle VII/c must I cut out all the flood holes on the top deck?????. Is it necessary or can I get away with only cutting the flood holes on the sides of the hull?????
Thanks LG
Thanks LG
RE: Engle VII/C
ORIGINAL: Rogue Sub
