IS this model good to convert?
NY
[link]http://www.hobbytron.com/model/U99UBoatRevellGermanyModelShips.html[/link]
I looked at this and was wondering if it was good enough to convert. Also how big is this in length height etc....
Thanks.
Thanks.
Converting the U99 would be a challenge. This model is about 1.5 ft in length, about 2 inches wide. You would have to install nano-sized radio equipment. Someone at Subpirates tried converting this model but so far no news. If you want a U-boat model I'd recommend the Revell 1/72 Type VIIc or VIIc/41.
Sure:
Trumpeter's 1/144 Kilo and Seawolf. I've converted the Kilo, space is limited but big enough compared to others. The Seawolf is even bigger lengthwise.
If cost is an issue, get something like the Krick U boat, Dumas Akula or Robbe sewolf. Overall cost will be less and its much easier to build than the plastic conversions.
NY
Wait whats a krick u-boat? Can you provide me with a pic? Also i looked at these people who build trumpeter seawolfs. One runs for 700$. Its nice though. Also what pump is used in a piston or static diver. Is there like a hydraulic type pump with a motor and prop?
NY
Oh never mind i remember that sub. It looks very nice. I put all the components together extra accesories, radio, esc, etc.... It added up to 650$ i think. What do you really need to get this sub working?
NY
This one doesnt look too bad. What does it mean "resin model" also is this model solid? And one more thing I saw these watertight seal for pushrods it was a rubber thing. It llooke like umm.... you know the bendy straws. Well the part that bends, you see how that has this pattern that allows it to bend. Well i saw a pushrod seal that was rubber and looked like that. Is that a good seal.
ORIGINAL: GreenAce92
NY
Here they are man these virginia class are smokin!!
http://www.geocities.com/submarineworks/virginia.html
