Go Back  RCU Forums > RC Boats > RC Submarines
 How to imitate the type VII wooden deck? >
RC Submarines RC submarine discussions.
Old 08-15-2010, 05:41 PM
Default How to imitate the type VII wooden deck?
Not only for scale look, but also to convert the kit to RC: the decks had many holes, or slots, so to speak, in order to let air escape when diving, and the decks provided by the Rvell 1/72 kit don't have them.
Someone found a solution?
Old 08-15-2010, 07:46 PM
Hydro Junkie's Avatar
Default RE: How to imitate the type VII wooden deck?
What about a slotting tool used for the control surfaces on R/C aircraft? I'm not sure how big the slots are but it could work
Old 08-16-2010, 04:16 PM
Is buying the the wooden deck kit out of the question? The slots are all cut out already.
Old 08-16-2010, 05:59 PM
Buying the wooden deck is out of question. Not only the shipping is expensive to Argentina, but also I don't think it will arrive at my hands.
Old 08-17-2010, 09:02 AM
The simplest way to do it is to just use the kit's deck. Just drill some small hole to vent the air out. For scale effect just paint the deck recesses black
Old 08-17-2010, 09:54 AM
I'm seriously considering using the cutter to cut the slots, as a drill will produce round holes which is a no-no for scale effect.
Old 08-17-2010, 06:54 PM
Captain Nemo12's Avatar
Is it possible to use a small enough drill bit to drill some pilot holes and enlarge them out with a rectangular file?
Old 08-17-2010, 07:11 PM
I wish it would be possible, but the slots are a fraction of 1 mm wide.
By using a flat screwdriver and a small hammer, I punched some slots, not all because the deck started to soften. Some sanding is pending, maybe I'll stick to this method for the other two decks:
ID:	1485807   Click image for larger version
ID:	1485808   Click image for larger version
Old 08-19-2010, 10:22 AM
Those slots are only for scale appearance, no air is going to escape from there, unless your sub is deep under water (and then you'll be wishing you held onto that air to help you get back up!). The slots are too small that air wont be able to over surface tension of the water as you just go under.
Old 09-09-2010, 07:52 AM
I dremeled forn the lower part, and all the slots are opened. A job to be deal with a lot of patience, but with quite nice results. No pictures for the moment. Sorry.
Old 09-09-2010, 08:11 AM
Did it softened to a point where it can be easily broken?
Old 09-10-2010, 01:13 AM
No, but have to be very carefull about. I'll try to take and post some picture about.. By the way, I posted about your ballast system for TRUMPETER 1/144 SEAWOLF, didn't realized about english is the forum language exclusively and, of course, the message was removed. Posted again today, because I'm very interested in your system for my SEAWOLF.
Regards.
Old 09-10-2010, 07:14 AM
Ok, just go ahead.
By the way, I published an article in our site www.camne.com.ar (in Spanish), thereĀ“s a section related to RC submarines, my article
among others of interest.
Regards
Robert
Old 09-12-2010, 12:29 PM
Have the pictures but don't know how to load'em to the forum
Old 09-12-2010, 02:56 PM
DOn't you see the link below, outside this frame (when creating a response); "Click here to upload images and files"
Old 09-12-2010, 03:52 PM
I've tried with it, but didn't work. LEt's see again.
Old 09-12-2010, 04:00 PM
Don't understand what's happening, because the message saying the file is uploaded appears, but not in the reply as an attachment.
Old 09-12-2010, 04:03 PM
Well, at last it's done. HEre is another (poorly focused) from the lower part. The reinfordcements for longitudinal strenght are visible.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
