RCU Forums
-   RC Submarines (https://www.rcuniverse.com/forum/rc-submarines-119/)
-   -   will this plan work? (https://www.rcuniverse.com/forum/rc-submarines-119/3134193-will-plan-work.html)
newbie_boy 07-04-2005 12:12 AM
1 Attachment(s)
even though i am probably going to go with a kit for my first sub, i was wondering if these really crappy drawing that i drew will work. I guess you can call them very rough sketches.
http://tinypic.com/view/?pic=6prbwi
http://tinypic.com/view/?pic=6prbsl
It would be cool if they did work becuase then i would probably use them for my second sub or maybe my first one if i can't find a kit that i like. It would be great for your opinions. Thanks
I'm hopefully uploading the files just incase the urls dont work.
_iceman_ 07-04-2005 01:41 PM
RE: will this plan work?
that 1st sub drawing loocks like the [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXEMH4&P=0]megatech[/link]
newbie_boy 07-04-2005 02:26 PM
i was basing the idea of the puddle jump from stargate atlantis (hence the name). but do u think that the plans will work?
_iceman_ 07-04-2005 09:01 PM
i'm not much of a expert on subs [:o] but there are a few people around here that can probably help you out on it
newbie_boy 07-06-2005 09:09 PM
please somebody add on to this post.. please
Captain Nemo12 07-08-2005 10:00 AM
I'm not sure what the second drawing on the right represents but I think that it is the profile view of the sub. It also looks like that you are going with the classic two-prop steering system and a central prop for thrust, but I think that you could do without it. Use the two props on the side for steering and thrust, thus eliminating the need for an extra motor. If using this method, then I can agree that it looks a lot like the Megatech/Nikko/Mako sub in terms of steering. Is the motor/prop located at the top of the sub (in the second drawing) for diving purposes? I think this plan could work, you can use a PVC pipe for the main hull and maybe running the motors in the wet, or putting them in separate containers outside the hull. If you need more advices I'll be happy to give you some.
newbie_boy 07-08-2005 09:02 PM
thanks cap!
Thats was exactly what i was thinking. I was going to use like a 3 inch pvc pip for the hull and then like 1 1/2 or 2 inch pipe to put the motors in out side the sub. i was basing the whole idea off the puddle jumper from stargate atlantis, like i had said before. while i agree witht he whole back motor being removed, i have not decided. thanks for the opinion.
