RCU Forums
-   RC Submarines (https://www.rcuniverse.com/forum/rc-submarines-119/)
-   -   Need some input (https://www.rcuniverse.com/forum/rc-submarines-119/4558485-need-some-input.html)
Ripcut 07-29-2006 10:07 AM
Need some input
Hi All
I am in need of some assistance from those with experience. I have some time in on building model aircraft but am getting tired of flying for a weekend and repairing for a week so I thought I would try something less frustrating. I have converted a Revell U-boat VIIC and would like to to make it a static diver.
Here is where I need the "voice of experience"
I have some "pieces" left over from one of my weekend flying outings. In particular I have salvaged the retractable landing gear parts and was thinking maybe we could use use that for the ballast system ( Robert Mfg -- http://www.robart.com/air_systems/airkits.aspx) This is a pneumatic system that you pump up by hand to 150 psi and with the small reservoir tank it is only good for 3 maybe 4 cycles. I don't think that's enough volume for a reliable ballast system. I was wondering if I can convert it over to something like using Propel but I don't know what the pressure that would be and if the valves and reservoir tank can handle that. This sub is very small so size matters and the components I have fit nicely. Anyone know what the pressure on that type of system is?
Any tips, hints, ideas, criticisms would be appreciated.
Ripcut (Crazy Ivan)
Ripcut 08-02-2006 12:22 PM
RE: Need some input
well so much for asking --- thanks anyway
Taxidriver 08-02-2006 04:07 PM
RE: Need some input
You could make a closed recirculating air type ballast system with that. You the Robart servo operated controm valve to inflate a ballast bag (surface) and a small airpump to pump air from the ballast bag back into the storage cylinder to dive the boat.
Ripcut 08-02-2006 04:16 PM
RE: Need some input
Thank you
flyboybuster 11-14-2007 09:51 PM
RE: Need some input
I know it's an old forum, but did you try this system? Did it work? What type of pump did you use?
