Heng Long Panther II Tank Destroyer
#51
RE: Heng Long Panther II Tank Destroyer
Hi There a bit late made one last year.with correct suspension and gun .The lower hull can also be used with a standard Panther G upper to make the one in the Patton musium,and with a F type turret to make a Panther F.So I wont be buyine one.
regards pete
regards pete
#53
I forget who did it but someone on here once did a paper panzer based on the Sherman. It looked like an American Stug and was one of the coolest looking tanks I have seen.
Perhaps that might coax YHR into the what-if world. I know how you love your Shermans Dan.
Perry
Perry
#54
ORIGINAL: rivetcounter
This has the Thomas Benadini sound unit it’s based on a Tamiya chassis the upper Wanne is metal.
Well while we are all into Hollywood replicas why not ask the GOD of models Heng Long to make a Sturmelefant Ausf H mit KWK128 L56 or Tiger II Austwind with chrome engine grills and bull bars or a Sherman Easydude with sun roof, wide wheels, white walled tyres and quad 50’s that way we may just get something interesting like a Cromwell or Churchill.
#55
IL
Well actually they couldn’t for the following reasons, the engine requires a tuned length to give the correct backpressure to the engine making it more than twice the length would alter this in a negative way, also there is a heat element Panther engine had the exhaust pipes glowing bright red even in winter this would cause unbearable heat, what if one of the pipes broke the crew would be gassed, the heat could cause damage to the torsion bars then there is the extra space they would take up, if one studies the Elefant it’s exhaust vents at the sides under the sponsons before the citadel, exhaust pipes on the back plate is just an ill-informed modeller with the mechanical knowledge of a bimbo.
There are at least 2 companies now making this tank that at the time was just a figment of imagination, has no one noticed some severe drawbacks with this design the first being the inability to lower the gun the second being the large area where the driver wouldn’t be able to see the same would go for the gunner also there would have been a massive problem opening the engine hatch not to mention the engine being removed, Elefant had two engine running either side and the gun would not foul removal.
I personally like the idea of making some of the tanks that were planned, but never made it to production. The main thing I have against this tank is the motive. Why would the Germans take a very successful tank destroyer and move the compartment to the rear? As RC noted in this post, it would reduce visibility, make repairs in the engine bay more difficult, and prevent the gun from being aimed down.
ORIGINAL: Warlord_Link
Waiting for E-100.
First time I see this tank I think it is VK4502P.
Waiting for E-100.
#57
AB, CANADA
ORIGINAL: Perry S.
Perry
Perry
My concern over this has been reduced dramtically when I see it is someone who is taking Stock Heng Long panthers and modifiying them into what ifs. Fine great, all the power to ya. I thought HL actually had commited some resources and time to develop this fantasy tank, and that is what i was having an issue with, as I think that is the wrong way for this hobby to go. Brought back memories of WING THiNGY slot cars that overwhelmed the scale guys, and killed the hobby.
#58
The exhaust back-pressure theory would not be too big of an obstacle for the engineers to overcome and figure out. So I ain't buyin' that being an ex-auto technician and race enthusiast.
Besides, they didn't build these to last 20 years, they were to just get out in the field and make a difference ... if it had been built. So motors and fuel mileage were the last things on their minds.
~ Jeff
~ Jeff
#59
OK what about the space and heat, ah you are going to say this also can be overcome with heat shields but that then interferes with the fighting compartment where space is vital then there is still the problem with gassing the crew with a broken exhaust, you only have to look at the Elefant and modern AFV’s to see what would have been done and no modern Mercarver or APC has exhausts running through the fighting compartment to exit the rear, why would they it’s the most impractical thing to do.
Paper panzer’s are one thing at least they were in development of some sort but the fantasy tanks are just that fantasy
#61
GA
Rivetcounter knows his stuff. Thanks for the back-up.
Exhaust through the crew compartment and heat and all that stuff. Never would happen.
#62
Whatever and no need for back-up. It isn't worth arguing about something that never happened, especially if we look at it with blinders.
By the way, it's just a plastic model. It can do whatever the fudge it wants to do.
~ Jeff
~ Jeff
#63
a paper panzer it is not but look at the thing for a minute.
Lower silhoute, engine in front for crew protection and quick exits out the back.
reduces the need for lots of material so I would think cheaper to make.
only problem is you have to move the entire tank to shoot. great tank hunter with an 88 on board.
I like it, wish i would have seen it a month and a half ago, i would have scratch built it. now i will have to wait till my current project is finished.
#64
ORIGINAL: YHR
Yes I rememebr that one. I really liked it, and wondered why it was never a reality.
ORIGINAL: Perry S.
Perry
Perry
That was me being goofy.........
#65
ON, CANADA
That's a neat Goofy. Too bad that type of tank destroyer wasn't built. It would have scared the crap out of the Germans.
#67
Das ist Amerikan Sturmgeschutz 90mm L/48 Ausf. D, ya?
#68
ORIGINAL: YHR
Yes I like that thing. So plausible, makes you wonder why it never happened
the US did have some good designs on paper late in the war but they were all too late for the war and never got built. honestly I don't know what happened to the US as far as tank design goes. I guess they tossed all the good engineers at their aircraft and forgot about armour.
#69
There is a guy over in Germany I think his name is Christen he has been making a kit of this for a couple years now .
Jimmy
Jimmy
#70
Sherman TD !!!, I like it.
Could I save you picture? I will let my customer see it. He always converse stock tank to other tank maybe he will make it.
I want these tanks that He scartch build from Henglong tank.
Regards,
Jade
Regards,
Jade
#71
ORIGINAL: MAUS45
Das ist pretty close......I call it a Shermgeschutz. The nice thing about designing model tanks is.........all you need is a box full of spare parts and a few beers to remove mental limitations and start thinking "what if?"
#73
Good gawd! That Swedish tank is so awesome! Gosh, like a kid in a candy store.
I gotta stop looking at all of these that I cannot have. Ever since I built that tank back in the 70's from an Aurora kit I'd always had a soft place for one. That and I really like tanks without turrets.
~ Jeff
~ Jeff
#74
ORIGINAL: Panther F
~ Jeff
~ Jeff
The picture Itake are seem old, Iwill visit him again soon and will take more pictures.
I just recieve message from him that he already complete make 1/16 SU-100 and SU-152.
This new year he plan to buy Henglong Panther that make I think "Which tank he will converse to?".
#75
wow...those are fantastic..I agree the swedish tank rocks!...I wonder if it's got hydraulic suspension like the real one lol?
p.s I also REALLY like the "Shermgeschutz" a little higher up in the thread...WAY COOL!
