SLU with Sherman Chrysler Gas Engine
ON, CANADA
Finally, the long awaited SLU with Sherman Chrysler gasoline engine is ready. I received this video from the manufacturer this week.
[youtube]http://www.youtube.com/watch?v=zXLqG_SER0c[/youtube]
We hope to have some in stock next month.
RE: SLU with Sherman Chrysler Gas Engine
Tim,
I've noticed that you have to move the right stick to certain positions (up,down,center)and then move the left, for mg,cannon and forward movement. Is there a way to set up the TX so that say the right stick controls tank movement, and the left controls turret traverse, elevation, mg, cannon etc? This may just be me, but it seems there is a bit of a learning curve moving the right stick to a certain position for the left to work. Hope that makes sense. Just curious because I have some projects with the SLU in mind for the future, which will be for backyard battles and my In-laws might be a little confused with the controls. BTW the sounds are excellent.
Cheers,
Wade
P.S. 1000 posts woohoo
Cheers,
Wade
ON, CANADA
ORIGINAL: Rebellion13
Tim,
I've noticed that you have to move the right stick to certain positions (up,down,center)and then move the left, for mg,cannon and forward movement. Is there a way to set up the TX so that say the right stick controls tank movement, and the left controls turret traverse, elevation, mg, cannon etc? Just curious because I have some projects with the SLU in mind for the future, which will be for backyard battles and my In-laws might be a little confused with the controls. BTW the sounds are excellent.
Cheers,
Wade
Tim,
Cheers,
Wade
I set mine up as you described!
Strato50,
Thanks for the response, that makes me want one (or more) I have heard a lot of positive remarks about these.
Cheers,
Wade
Cheers,
Wade
I've got my slu setup so all drive one the right stick and the other functions on the left. You just need to swap two on the channels around on the rx or when setting up the slu,very easily done!
