2.4ghz to RX-18
Old 06-24-2012, 09:44 PM
Rebellion13
Rebellion13's Avatar
Default 2.4ghz to RX-18
While looking around on rctank.de I came across this http://www.rctank.de/product_info.ph...lvj0r6oh9j80e5 Now after its all said and done, you would be better off just getting the DBC, but for those that aren't interested in battling and want to use a better radio this might be the ticket. This is new to me, but others may have seen it.
Cheers,
Wade
Old 06-24-2012, 10:32 PM
borealis
borealis's Avatar
Default RE: 2.4ghz to RX-18
That is the IPI4HL board, from Ivano 'Scooter', the maker of the IBU.
It does work either alone (if you just want to replace the transmitter and gain momentum simulation) or in conjunction with a IBU compatible board for battling against other Tamiya-compatible systems.
Old 06-24-2012, 10:50 PM
lonewolf1300
lonewolf1300's Avatar
You can get something similiar from RC TANK AUSTRALIA, and its cheaper. At present it will work with a 6channel reciever but they are trying to solve a problem with 8channel recievers, which gives you scope to add options for doing other things on you tanks. I purchased one of their TURNIGY 9X transmitters which came with a backlight update pre-fitted and the software update cable for using EEPEE software to save copies of your templates and modify them. the radio was only aus$90, the heng long to rc converter board is only $aus 30. The radio comes with a basic tank template installed and has a recoil function set on channel5 for a servo, which you can alter the speed of going both ways, the only bad thing is there are no instructions at all with the radio but if you go on their website you can find out more about using and programming the radio to do lots of different things.
They do a lot of different boards to let you tailor you tank to your needs at a reasonable price and KEVIN will gladly help you if you are not sure about things as he helped me with my setup.
http://rctanksaustralia.com/shop/ind...1df1e2ed6c5f7b
Old 06-25-2012, 08:56 AM
blitzkrieg65
blitzkrieg65's Avatar
Hey All,
I sell the DBCRC2 without the IR components (picture below shows all the IR components and the 2nd sound card which comes with the full kit.) but I do include in the price $ 105.00 one sound card with a custom cannon sound and you have all the connectors
on the board should you want to upgrade later to the IR battle components, they will just be plug n play. Here are the specs for what you get
Adjustable weight classes damage (1, 3, 5, 9)
reduction in speed when damaged (approx50%@1,1,1,1) (approx25%@1,2,3,5)
reload times (2, 3, 5, 9) in seconds
15 seconds from death to mobility (engine shuts down on destruction, restarts and ready to move after 15s)
temporary invulnerability after death (20 ,15, 12, 10) in seconds
Momentum/inertia option
affected by weight class
slow acceleration
coasts to a stop
soft braking (partial opposite stick)
hard braking (full opposite stick)
Super Spin disable option
Enabled by default
disables super spin completely
allows much smoother control of skid-turning at low speeds and when accelerating into a turn from rest
Radio failsafe: sets tank to neutral after losing radio signal for ~1/4second
Remote config after power on (until ignition pressed)
You can program with your Hobby Radio
can (en/dis)able Momentum
can (en/dis)able Super Spins
useful for having "realistic" motion for recreational driving, but full capability when battling
useful for disabling momentum when driving in confined spaces (protects fragile add-ons)
can (en/dis)able recoil blocking
IR input & hit LEDs interface compatible with Tamiya "apple"/TBU or DBU
IR output compatible with standard IR LED (including Tamiya's)
Phil
ID:	1775610   Click image for larger version
Old 08-03-2012, 12:02 AM
Elefant
Elefant's Avatar
Hi,
Anybody knows where I could find a copy of the IPI4HL instructions ? Dominique didnt include one in the parcel.
Old 08-03-2012, 04:04 AM
borealis
borealis's Avatar
Here it is, fresh from PDF distiller.
The picture inside might not be recent, though (I think the latest version do have the signal wires soldered on board), but the instructions are.
File Type: pdf
Old 08-03-2012, 07:39 AM
Elefant
Elefant's Avatar
Thanks borealis !
Dominique just sent me the instructions by email too.
Many thanks to both of you
Old 09-30-2012, 08:04 PM
rchotel
Hi
Does anyone know how to connect the IPI4HL to a futaba 2.4 system. No matter what i do i cannot get it to work. All i get is the smoke system operating
thanks for any help
Old 09-30-2012, 11:07 PM
borealis
borealis's Avatar
Tried changing the transmitter modulation to PCM?
I have sent you the builder's (Ivano) email, though.
