small scale fasteners
im new to this hobby so if anyone could refer me to a site or sites which supply small scale fasteners (nuts/bolts/washers...et cetera) i would appreciate it
im mainly interested in anything smaller then 2mm and things like square head bolts,nuts....et cetera.
RE: small scale fasteners
These folks are wonderful. It is a German firm ( duh ) however their site is easy to use. They have hex head screws in sizes difficult to find; plus they sell taps for them...
Their products are simply wonderful
http://www.knupfershop.de/shop/index...64&cp_tpl=main
Two orders I've made with them and even though they didn't know me they sent the order first and the charge came with it.
They have M 0,6 hex heads which are tiny.
Closer to home there is Morris:
http://www.jimorrisco.com/index/group/id/10
I purchased their 0-80 and 00-90 hex head screws and they're wonderful
And the old standby Coles' Power Models:
http://www.colespowermodels.com/index.html
Coles' over the years has saved my bacon with their 1-72 hex heads in steel
Jerry
Jerry
Yup, me too. Try threading 00-90 holes in aluminum. I'm shaking in my boots when I envision trying to thread even
smaller ones.
The other night I was threading a 4-40 hole ( large for me) in a piece of raw tool steel for a fixture I'm making. First hole went perfect.
second hole was nearly done, abundant lubricant. Wasn't using a threading attachment on the mill this was freehand.
Actually I do all small threading smaller than 8-32 by hand as the small taps need to really be felt as they're working. Machine torque is too great.
Anyway a tiny bit of torque, and I mean I barely touched it and *snap*. Oh I was PO'd. I usually
will take the time to remove it if possible. The remains of the tap are now a permanent part of the assembly, a rolled pin
will complete the alignment as the one good screw is sufficient. But annoying? Oh yessssh. I believe the tap was fractured
but it just wasn't visible. speaks to a good rule of thumb. Toss a tap if it doesn't cut well or seems off.
The fixture? It will be used to punch the two holes in .005" thick steel to make the safety clips for the 8 hub bolts on my jagdPanther's
roadwheels. This is why everything takes me so long.
A sample:
Jerry
ORIGINAL: Tanque
smaller ones
Jerry
smaller ones
Jerry
Doing 0-90 bolts and screws are easy, ya drill a hole twice as big as ya need and superglue the bugger in.......it works for me! Go ahead and hate me........
My current project has 198 brass screws on it, 1/72 and 0-80 (and a buncha rivets) ......all of them glued in. I'll post some WIP photos today.
Seriously, using small size taps has been a nightmare for me all of my life. And I have a workbench with every size "easy out" ever made to prove it.
Rex
ORIGINAL: Codys416
Welcome to RC tanking. I'm sure you will enjoy this hobby....it is a blast if you are into modeling, RCs, big machines and history. I see you are in NY. I was born in NYC. We have a large RC tank group in the NYC metro area and beyond. NEAD has over 100 members. I sent you a PM regarding membership. Even if you do not join NEAD please feel free to attend one of our battledays. Don't worry if you don't have a IR battle ready tank....you can try one of mine. Our next battleday is this Sunday in Florence, NJ.
Here is a link to the post: http://www.rcuniverse.com/forum/m_11173030/tm.htm
Come and see for yourself. Bob, NEAD CO
