wsn123?
Old 01-14-2013, 03:41 PM
Rebellion13
Rebellion13's Avatar
Default wsn123?
I figured I would post this here instead of on in a -pm- to you, since it might help others with the same question
You stated in your panther you use the elmod eco and the benedini tbs, have you used the elmod baster with it, and is there a noticeable difference in using the benedini over the blaster? Also aren't you limited to the various sounds of the benedini (e.g. track sounds) as compared to the the blaster? Hope this makes sense what I am trying to say.
Cheers,
Wade
Old 01-14-2013, 06:47 PM
Martellus
Default RE: wsn123?
Doesn't bendini have a data cable you can buy for that?
Old 01-14-2013, 09:35 PM
YHR
YHR's Avatar
Default RE: wsn123?
The Benedini does not have a separate address for track squeaks. If you want track squeaks you have to overlay them in the running address file.
Old 01-15-2013, 08:31 AM
wsn123
wsn123's Avatar
Default RE: wsn123?
ORIGINAL: Rebellion13
Cheers,
Wade
You mean Elmod Blaster?
Sorry but I used the old version of Elmod Blaster only , a long time ago , now Im using mainly Benedini TBS Mini with Elmod ECO (and some Tamiya units in another tanks).
So I dont know how the sound quality is looking in Elmod Blasters IV now . Benedini uses 8 bit 22 kHz samples only (the same as Elmod Blaster) but its quite enough for my ear - the main advantage of Benedini (for me) is the engine sound project structure: I mean two additional samples - for accelerate and decelerate which improves engine sound reality.
But as You said in Benedini only one sound can be played simultanously (in new Elmod Blaster IV , five sound channels are possible !!! ) . Personally I solved this problem in Benedini using Audacity software - to the existing engine soundtrack Im adding the second one with tank track rattle sounds. Audacity can mix both soundtracks and create one "wav" sample with two sounds played simultanously .
Very importrant factor in sound units practice is very good quality speaker in box (as big size as possible) . For example 2,5 inch Visaton speakers in XXL box from rctank.de for 1/16 scale tanks are very good or biger size speakers if they could be fitted in Your tank.
regards
Piotr
Old 01-15-2013, 10:31 AM
YHR
YHR's Avatar
Default RE: wsn123?
I think the Benedini can play two sound simultanously. Ie when the engine is running you can still fire the cannon and machine gun and not have the engine noise cut out, so it is at least two.
Agreed I really like the Benedini sound file structure. Very simple to create your your own good sounding files.
For wheel squeaks use a sacrificial hub, and produce real ones random ones.
Old 01-15-2013, 11:34 AM
Rebellion13
Default RE: wsn123?
Thanks guys, I have been dabbling with the audacity software the past few months, I love that program. I have done B17 bombing runs, and added flak fire to it, sounds really good. I was just curious to see if there was an advantage to using the benedini sound over the elmod sound.
Cheers
Wade
Old 01-15-2013, 12:36 PM
YHR
YHR's Avatar
Default RE: wsn123?
WSN123 stated
This is the main one. Makes it very easy to build transitions between idling and running.
wsn123
wsn123's Avatar
Default RE: wsn123?
ORIGINAL: YHR
Yes You are right, I was thinking about /the main/ engine sound only....
additional sounds like MG can be played simultanously with engine sound.
