Reload this Page >
witch is best gearbox for hl tiger 1 ??
Old 06-10-2013, 08:13 AM
schutzstaffel
schutzstaffel's Avatar
Default witch is best gearbox for hl tiger 1 ??
hi , decided to start up the old hl tiger 1 , left it with a damaged gear box 6 years ago , need the gearbox that wont break .
wich one do you recomand , the matotoys 3:1 , the real steel gear ones or any sugestions , want to settle the problem for good.
the metal gear uprade from matotoys did`nt last the finger test when i was instaling it ! [:'(]
also i notice that the tank does`nt turn anymore ( cicrcuit board problem ? ) any sugestions of a trouble free board for the old hl tiger ?
ID:	1890494   Click image for larger version
ID:	1890495   Click image for larger version
Old 06-10-2013, 08:15 AM
schutzstaffel
Default RE: witch is best gearbox for hl tiger 1 ??
can i put the tamiya gear box in it ?
Old 06-10-2013, 09:22 AM
Triton-50
Waltersons do a nice gearbox for HL,
You don't say what board you have at the mo? The Rx 18's I find are good enough.
Hope this helps
Stu
schutzstaffel (06-22-2020)
Old 06-10-2013, 10:42 AM
Green Amphibian
Green Amphibian's Avatar
As an upgrade I have found that the real steel gears work fine for me, even with the upgraded 400 motors I use. Taigen is marketing a new set of gearboxes with brass gears that are billed as 4:1 ratio also. I have no personal experience with those boxes however. I would also tell you that an upgrade to the electronics is probably a good idea. There are many choices beside HL that will give you more realistic functionality and 2.4 radio operation that is much safer. I guess it all depends on what you want to do and how much you are willing to spend. You might want to check out the Clark boards TK22, DBC3, El-Mod, ETC. before making a decision.
Herman
Old 06-10-2013, 11:15 AM
tomhugill
Those taigen gear boxes are just the asiatam low profile ones which have been around years. Your best bet is either go Tamiya (buy from Jason's store on eBay) or the taigen black metal 4:1s. These are a drop in fit and I've heard nothing but good things. The tamiyas will require more work but also very good!
Old 06-10-2013, 03:15 PM
Strato50
Strato50's Avatar
I just installed the Taigan black steel 4:1s in my Tiger, they dropped right in and work great. I have 3 sets now and all 3 are very smooth an sturdy.
Just make sure if you order them that you're getting the 'real' ones, with ball bearings on the drive shaft. I've seen too many eBay auctions listing "Brand new Taigen steel gearboxes!!" that are still the same non-bearing HengLong type with painted black pot metal... keep an eye out.
Old 06-10-2013, 07:51 PM
PanzerAce
From that middle pic that appears to be either an RX-13 or and RX-14 board.
Old 06-11-2013, 12:34 AM
schutzstaffel
wow , thanks a lot friends , really good replies from you all .
have the rx 14 in it ,i was one of the first who putted a fan on the rx13board(lasted 2 years with it then stopped turning ). also have another spare one , but will probably buy the rx18 board (just notice that they exist with you
for the gear box , i`m checking the taigen , walterson and the tamiya and real steel , decisions..descisions...
thanks again , realy appreciated , you save me a lot of time !
on the pic , you can see the 6 years dust buid-up on the tank with my fan mod .
