Reload this Page >
Upgrade volume pot on HL tanks?
Old 04-21-2014, 04:49 AM
DirtyBird69
DirtyBird69's Avatar
Default Upgrade volume pot on HL tanks?
Haven't been able to glean much info on the subject, The word is that an upgraded pot will improve the sound quality on the factory RX-18 set-up? Has anyone done this, would appreciate some feedback on the subject...
thanks
http://www.shop.immortalhobbies.com/...7698768848.htm
Old 04-21-2014, 08:38 AM
mcovalsk
How a new pot will improve the sound quality?. I heared this and sounds ridiculous. High quality refers to the pot itself. Clean sound..... nothing.
Old 04-21-2014, 09:29 AM
YHR
YHR's Avatar
A new volume pot will do little to improve the sound.. The basic Heng Long sound byte is poor.
Old 04-21-2014, 12:25 PM
ausf
ausf's Avatar
If the pot has dead spots or drops out when turning it it may help, but otherwise it's just a variable switch it can't make sound better.
Old 04-21-2014, 01:29 PM
DirtyBird69
From what I'm hearing it basically just eliminates any crap in the sound that the cheapo HL pot allows to get through....so you get crisper cleaner sound effects..also does the same for Clark/DBC boards/etc....at least that's what I'm told. They are cheap($10) so if it helps even a little then its worth it to me lol..
Old 04-21-2014, 01:39 PM
YHR
YHR's Avatar
The only improvement will be on the connectivity, as Ausf mentioned. If the HL one is not cutting out you will see virtually no improvement As a matter of fact you can run a shunt across the connections and bypass the thing completely.
