Airsoft Paintball BB's
Old 06-26-2014, 03:47 AM
welchgc
Default Airsoft Paintball BB's
Hey,
Any of you with airsoft tanks ever try using the 6mm paintballs? Did they work or just jam? Any comments/thoughts would be great.
I got three Taigen Airsoft.
G
Old 06-26-2014, 03:59 AM
Strato50
Strato50's Avatar
I remember this being discussed before and I think the general consensus was "well a broken paint BB INSIDE my tank is probably a bad thing..."
No personal experience though.
Old 06-26-2014, 04:21 AM
Imex-Erik
Imex-Erik's Avatar
I have been asked this question at least 100 times.... From a company standpoint we don't recommend them. They can cause problems if they burst and you know the rest. We do not cover any problems if they are used in our airsoft units.
Now that being said, they are cheap and easily replaceable. A unit cost about $10 and can be swapped in under 5 minutes on most tanks. If you break a paintball in the tank you can just open the turret, push the airsoft motor out, replace the plastic firing unit, then reassemble. You can then clean or throw away the other unit later if you wish. You will have to clean that barrel just in case, you can do this while you have the airsoft unit out anyways. So if you are prepared to spend some time figuring out what works best with what then it is totally possible. I have heard both success and failures on the paintball end. Just be careful and make sure not to shoot anyone/anything ok?
Old 06-26-2014, 05:03 AM
YHR
YHR's Avatar
I have used Paintballs in these tanks. Biggest fear and issue is if a paintball breaks in the chamber. This has not happened to me.
Be warned that with a stock gun you have to be with 10 m to get a good break with the paintball. Anything over that and there is a chance the paintball will just deflect without breaking.
Old 06-26-2014, 05:28 AM
borealis
borealis's Avatar
Best chance to break the paintball using a stock gun was with the PZIII (most powerful gun available, due to the short barrel). But the airsoft guns could be made more powerful by shimming or replacing the internal spring and by replacing the barrel with a tighter one cut from spare airsoft ones (and by discarding the stock BBs for something more professional).
Old 06-26-2014, 06:47 AM
Rustytrax
LOL you could PolarStar a Jagdtiger / JadgPanther easily. It would be a true TD for sure. With a 300-500 fps .40g bb it would easily punch through a Sherman. Those poor all plastic HL tanks would be fodder.
Old 06-26-2014, 08:15 AM
Imex-Erik
Imex-Erik's Avatar
We have an airsoft 450 fps sniper rifle here and MAN does it hurt. I couldn't imagine a metal bb haha.
Old 06-26-2014, 11:57 AM
philipat
try the marking bbs instead...less risk of breaking. somehing like this: http://www.walmart.com/ip/Crosman-Ma...000ct/15103407
Old 06-26-2014, 01:21 PM
Imex-Erik
Imex-Erik's Avatar
Those are a bit different from ones I have seen. Usually they have the powder chalk type covering on them. You should test them for us
Panther G
And we would see just how fast you could escape a tank meeting just after you started punching holes through other peoples models when so many put many hours in customizing and painting down to the last detail.
I assure you you would not get away so easily.
That is the main concern about airsoft BB's. especially airsoft paint balls.
Old 06-26-2014, 01:27 PM
Imex-Erik
Imex-Erik's Avatar
I tell you what, whoever shoots my models better be fast. I can run pretty quick. Only my cars/trucks are meant for destruction. Isn't that funny how it works?
Old 06-26-2014, 02:36 PM
ausf
ausf's Avatar
Oh yeah, I have a Thompson replica in that fps range. The only time I fired at someone they were running across the yard about 80 feet away and a short burst left them with welts.
Old 06-26-2014, 04:02 PM
Perry S.
Perry S.'s Avatar
400 fps gun from my JagdPanther...
Never shot at a person or anybodies tank but I straight up murder empty pop cans.
rb67mustang (08-10-2023)
Old 06-27-2014, 04:24 AM
Imex-Erik
Imex-Erik's Avatar
I would be interested in the build if you have it logged 400 fps lol that is hilarious.
Old 06-27-2014, 06:33 AM
ted7191
Hi ausf , what is the make , model # of your Thompson . I want one ! Thanks.
Old 06-27-2014, 06:43 AM
ted7191
Erik , same question that I asked ausf ; what is the model/maker of your airsoft sniper - thanks . Just picked up a Panzer IV 161/1 winter camo ; very cool . I can't get the glow in the dark BB's to glow. Put them in the sun all day long and nothing ? Lastly , I also picked up a "quick charger " and set it on 4A . 15 minutes . Hobby shop guy claims it is safe ?
Old 06-27-2014, 07:32 AM
Imex-Erik
Imex-Erik's Avatar
Mine is just one of the sniper rifles we sell here at IMEX. It is spring loaded. I'm not a big fan of having to go buy gas cartridges. As for the battery 4A seems kinda high for a NIMH battery. If it is a Lipo it shouldnt be too much of an issue. Can you get me some specs on the battery? I never charge more than 1C unless it is on my high current batteries for the cars.
Old 06-27-2014, 08:04 AM
ted7191
Erik , charger is in my luggage ; headed to the beach house . I'll get back to you with info this weekend. Thanks , I can depend on you ; my son said almost the same thing. Nice guy at HobbyWorks , but ...
I'll check your site for the rifle . Thanks , again
Old 06-27-2014, 08:15 AM
ausf
ausf's Avatar
Here's a link to it. I bought it pre-Xmas, I'm pretty sure it was $100 then. I've read reviews that clock it well above specs and I know I've put 25s through sheetrock @ 30 feet with it. There are upgrades to weaker springs so it's more skirmish friendly. I love it for just messing around, it's too strong to use with my kids. I'd go with the drum mag next time, full auto goes through BBs very quickly. It's heavy and well made, I picked up a replica sling for it too.
http://www.pyramydair.com/s/m/Thomps...Specifications
Old 06-27-2014, 12:12 PM
Imex-Erik
Imex-Erik's Avatar
Woah! I just checked the specs on that and 4A is a VERY high charge rate for a NIMH battery. That is over a 3.5C charge rate if the battery is a 1100mAh battery! I personally would charge it at or less than 1.1A. If you are worried about run times I would purchase another battery, I wouldnt risk it. I always try to play it safe with batteries, I have never had a fire with mine.
You also have the option of LIPO batteries too. A simple LVA/LVC on a 2 cell LIPO (or 3 cell LIFE battery would probably be closer to stock voltage) will monitor voltages for you and alert you when it gets low. A lipo of the same mAh will most likely be a lot smaller and powerful than the stock NIMH battery. It will also last a lot longer Just be careful please! I can't stress how much a LVA or a LVC should always be hooked up even if your ESC has a cut off. Safety first!!
Old 06-28-2014, 03:43 AM
welchgc
Thanks for the PB info...probably just stick to BB's
Old 04-16-2023, 03:43 AM
Crius
Deleted, at first I didn't see how old this thread is.
Old 08-10-2023, 08:25 PM
rb67mustang
OMG, 400 fps from an RC Tack!!! This is really crazy!!!
Old 08-10-2023, 11:17 PM
Vastris31
Hey there,
I haven't personally tried using 6mm paintballs in my airsoft tanks, but I've heard mixed opinions about them. Some players have mentioned that they can cause jamming issues due to the slightly larger size compared to traditional airsoft BBs. It might be worth testing a few rounds to see how they perform in your Taigen Airsoft tanks. Good luck and let us know how it goes!
Old 08-11-2023, 01:33 AM
Max-U52
I've used them, I think I even have a video somewhere. I've never had any problem with them breaking inside the air soft gun, but I did have a problem finding airsoft guns with enough power to make the paintball break on impact. If you guys are interested I'll see if I can dig out the video when I get home from work. Now, my 1/6 Hetzer shoots .50 caliber paintballs, and that's an entirely different animal.
