DBRC 3 Benedini and Asiatam Recoil
AB, CANADA
I have ever only done this once. I think I removed all the wiring and the just used the fundamentals of wiring up electric motors to reconnect it to the RX 18 . The RX 18 will supply the energy and the TBS will supply the trigger pulse to engage the recoil. Use the "on sound" feature of the TBS to energize an output pin when the cannon sound is fired. Use the output pin of the DBC3 to supply the flash. If you do this everything should be sync'd up
Cheers
Cheers
