Heng Long wild recoil
"Heng Long, Taigen & IMEX tanks which are triggered by the microswitch on the rear of the Airsoft/Recoil units."
Could this switch be cut or removed instead of buying another unit?
The cannon firing sound and recoil are linked. If you remove that recoil plug from the motherboard you will remove both.
http://www.ebay.ca/itm/ISD1820-voice...item488c05199c
