Fastmike HL "worm" gear drive.
Has anyone tried a Fastmike Heng Long "worm" gear drive? If so, what are your thoughts on it? Looking for first hand users not "I heard from a friend" information. I have one and I am looking to see if my findings match other users.
Trying not to say anything as I was hoping to hear untainted input to compare with. I am still in the process of playing around with mine but so far not impressed with performance. It looks great but looks will only go so far.
Yeah, I guessed you didn't like them by your wording. From what I see on ebay the 3D prints look a little rough but the gears look good. I am considering buying the gearset but not the whole gearbox.Which reduction did you get?
** Scale speed of 55 mph is my target while attempting to keep the mods simple and straight forward. Currently at a solid scale 45 mph across my modern tank line up. Could be faster but my tanks are a bit heavy from added weights to give them a solid 50/50 balance front to back and thus smoother cross country performance.
IF you just want to increase your speed a bit. get the Tamiya motors that come with that huge brass gear on them. Gently heat the gear with a tiny torch and pry it off with needlenose pliers. The gear will pop and fly away as there is air trapped inside the shaft hole..
Then put your Hl pinions on the Tamiya motors and your HL will haul butt. I did this to mine with plastic gears, glued the clutches and I use it in IR battle a lot. Its a very reliable tank for me. Its a Sherman by the way.
Well, I know little about its performance; but, the printed parts file seem to be available for free on THINGIVERSE: https://www.thingiverse.com/thing:2725197
Springman
Springman
Springman
Springman
Dead link for me
sorry, try this one:
https://www.thingiverse.com/search?q...75a904f75eeb27
You may have to join to access.....its free.
Springman
Springman
