Reload this Page >
Tamiya FineSpec 2.4G radio review video
Old 08-07-2019, 07:18 AM
heavyaslead
heavyaslead's Avatar
Got mine yesterday, and works great.
Just assigned channels and reverse and buttons and go
The manual is all in Japanese, so the video helps alot.
For right stick DRIVE/STEER and left stick gun/turret control I set the Channels:
CH1 -- CH1 reverse
CH2 -- CH3
CH3 -- CH2 reverse
CH4 -- CH4
Of note: Apparently the binding is exclusive to the FineSpec receiver model. Tried binding with Futaba FHSS and FASST receivers with no success.
Old 08-07-2019, 10:06 AM
Pcomm1.v2
Pcomm1.v2's Avatar
Default Your welcome.
Originally Posted by Panther F View Post
Thanks for the link John! Radio arrived in just 4 days.
Happy to help.
Pit, great FineSpec video!
Old 08-07-2019, 10:33 AM
tch2000
I’m bout to order mine. As this video will help a lot. Thx guys.
Old 08-07-2019, 10:36 AM
tch2000
Originally Posted by Pcomm1.v2 View Post
For clarification, it was Tamiya USA tech people who made the Futaba FM radio recommend for operating the Leo 2 and that was years ago. The Futaba 2.4 was new to the market at that time and did not play well with the stabilizer unit, nor did the Tamiya boys have a 2.4 radio to test with the Leo 2 back then. They recommended what they knew would work here in the USA.
The Tamiya Fine Spec radio is super, plug and play, my type of radio for sure, haha!
so this radio will work with the Tamiya leo ?
Old 08-07-2019, 10:52 AM
Pcomm1.v2
Pcomm1.v2's Avatar
Ask Pit, he is building a new Leo 2.
I still use a Futaba FM for my Leo 2, ‘cause it was built over a decade ago.
My FineSpec is for a second Abrams build, instead of the new Tamiya Sheridan and hello Ken Myers.
Old 08-07-2019, 12:06 PM
  #31
pitstain
I had a YouTube commenter say it does not work 100% but I will find out for sure once I get far enough into my build.
Old 08-07-2019, 10:11 PM
  #32
tch2000
thx buddy
Old 08-08-2019, 06:14 AM
  #33
heavyaslead
I verify it works with the Leo2 electronics, seamlessly...
Old 08-08-2019, 06:42 AM
  #34
Pcomm1.v2
Pcomm1.v2's Avatar
Default Question?
...with the Tamiya Stabilization Unit Accessory too?
Old 08-08-2019, 08:25 AM
  #35
Imex-Erik
Imex-Erik's Avatar
So what exactly stops these other radios from working? Is it because you can't adjust things like endpoints or switch assignments?
Old 08-08-2019, 09:30 AM
  #36
heavyaslead
What Tamiya had claimed some 10 years ago (this is old info now), was some computer controlled mixing would not read properly with the DMD unit.
i.e. the computer coded functions on the radio may not properly be understood by the DMD unit as the DMD unit is still a manual setup with radio
Old 08-08-2019, 09:37 AM
  #37
Imex-Erik
Imex-Erik's Avatar
Now that I think about it I can think of why this may of been an issue. There used to be a difference between aircraft and heli radios if I remember right. Maybe the default mixing cause an issue. I know some of the Spektrums stuff still to this day gives some of our customers issues until the default mixes are removed, maybe this was what they were speaking of. That makes much more sense that the info was 10yrs old. I thought this was a few years old info, not 10.
Old 08-09-2019, 03:33 AM
  #38
heavyaslead
OK for full disclosure, I did extensive testing with the Leo2A6 electronics and programming the FineSpec
Here are the results:
1. Out of the box: All functions worked (yes even the GBS system); except the volume up and down; still don't know what the Brake function does though
2. Changing button assignments: Finicky, sometimes what is displayed will not be the function programmed, for instance I program #3 to be Main Gun and another function button not touched will change and the text shown will be different than the function it performs. At one point I had the Brake text showing and the GBS function was what the transmitter actually sent.
Perhaps you have to WRITE the program after each change instead of multiple changes, I dont know.**
3. You can program multiple buttons for the same operation, though it seems if you replace a function, it tries to reassign that lost function to another button. Still figuring this one out.
4. Also noted that making WRITE cahnges to buttons forces defaults of the Channel settings, so do the button changes first then Channel changes in that order.
5. Fail Safe is built in to the system (ON from factory)
Old 08-09-2019, 08:40 AM
  #39
Pcomm1.v2
Pcomm1.v2's Avatar
Thank you! John
Old 05-03-2022, 03:05 PM
  #40
1Randall
the only place to get these radios now is Japan. do they come with English instructions
Old 05-03-2022, 04:15 PM
  #41
jarndice
Location: Hemel Hempstead,Hertfordshire, UNITED KINGDOM
Sorry no they don't,
The instructions are in Japanese and they were never really rated all that highly.
There is a U-Tube tutorial available if you are really interested in buying one.
Old 05-04-2022, 03:01 AM
  #42
1Randall
I ordered one a week ago on Amazon but the Japanese have some kind of week long holiday so they will not ship for another week
Old 05-04-2022, 05:09 AM
  #43
Crius
Are extra receivers for this radio readily available at a reasonable price?
I know the guys that have them swear by them, but I'm still trying to justify a radio that cost so much I could get 3 I6 transmitters for the same price. Just what is it about this radio that makes it worth that much money?
Old 05-04-2022, 05:54 AM
  #44
1Randall
This would be my first radio like this one, so I cant tell you why its worth that much. From what I have seen you just plug in and play.
Old 05-04-2022, 09:39 AM
  #45
Panther F
Panther F's Avatar
Has anyone tried the FrSky Taranis Q X7 radio for a Tamiya tank? Saw it mentioned on another RC forum and never heard of it.
Old 05-04-2022, 10:56 AM
  #46
Rad_Schuhart
Yes, and is an excelent radio, infinite better in any aspect than the Finespec or other tamiya/futaba radios.
Old 05-04-2022, 11:38 AM
  #47
tankme
I own a Taranis Q X7 and it is a pretty good radio. I've got it setup to run my Tamiya Sherman, Tamiya KV-2, TCB based Hooben ZTZ-99A, and my TCB based HL Type98. Only issue I have with the Q X7 is battery life, but I've solved that. The NiMH battery that you can get with it sucks, but if you have a newer HL with the 18650 (2P1S) based main batteries, they work in the Q X7. Just use them by plugging them into the radio using the balance plug. The last sooooo much longer than the standard battery. There are tons of 2P1S 18650 packs available, but make sure they have a JST balance plug.
Old 05-05-2022, 03:21 PM
  #48
RichJohnson
RichJohnson's Avatar
The nice thing about the Tamiya fine spec is you can store a few models in memory and the designated buttons specifically work the functions on the Tamiya MFUs for main gun, machine gun, spot light, head lights etc. just saying. For some people, that is a perfect option for their Tamiya as it’s all they need.
Old 05-05-2022, 04:09 PM
  #49
1Randall
just got a email saying my Tamiya fine spec will be here friday. I know the instructions are not in English, so I will try to muddle through. If I get stuck I might have to ask a few ? here.
Old 05-07-2022, 07:53 AM
  #50
1Randall
just got my Tamiya fine spec Friday. The instructions are in Japan, but in English on the radio itself. I rev. 2 channels and away I went. Now to finish the tank off
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
