Leopard 1 1/8 running gear
I am offering a Leopard 1 running gear set scale 1/8 with high end quality.
set consists of:
14 arms, 14 bearing housings, 14 torsion bar springs
-arm and bearing housing are made from stainless steel
-torsion bar is made from a special alloy to represent the original spring properties while at the same time keeping the large diameter of the original spring (diameter is 5,5 mm)
-torsion bar has a tested and guaranteed torsion angle of 70 degree (permanent deformation starts at 85 degree torsion angle)
-ends of the torsion bar have different toothing (26 and 28 teeth), so the adjusting of the arm can be done in steps with about 1 degree
-every arm is supported by 3 bearings and 1 shaft seal, therefore the hull can be built completely watertight
-drawings of the hole patterns of the hull will be provided
Price including shipping is 2490 Euro
set consists of:
I don't mean to be rude but before I looked closely at the photos I though that for 2490 Euros it had better come with the rest of the tank...... top marks for workmanship and attention to detail, wish I could afford to have a large scale tank.
The rest of the tanks like 50k. Makes warslug look cheap
