Help with Benedini sound
Old 05-23-2020, 05:07 AM
tachouman
tachouman's Avatar
Default Help with Benedini sound
Hi all,
Anyone here know how to get the Benedini TBS Mini V2 to work? I cant get the sound to work, I wired it according to the instructions, every thing works fine except no sound comes out of the speaker. I tested the speaker on a Tamia MDM and it works fine, but when I hook it back up to the model Im using it in I get nothing, and when I try to increase the volume I get knocking and statics. I even bought a second module but still doing the same thing.
I can post pictures and videos if necessary.
Thanks.
Old 05-23-2020, 06:54 AM
bowlman
Did you order it with sound files already installed .
Jimmy
Old 05-23-2020, 07:17 AM
Crius
Hopefully Rad will chime in here, he's done some great tutorials for the TBS mini and mikro, and he should be able to help you.
Old 05-23-2020, 07:26 AM
tachouman
tachouman's Avatar
Jimmy
yes, I ordered it directly from Benedini with preinstalled sound.
Old 05-23-2020, 07:33 AM
tachouman
tachouman's Avatar
I’ve been struggling with this for over a year, I even spoke to Thomas Benedini. I thought it might be defective so I ordered another one got it yesterday but ended up the same results, no sound coming out. I can’t figure out what’s wrong I tested the speaker, works fine, hooked up the sound to another speak, and another controller, and a different radio and receiver, no luck
Old 05-26-2020, 05:13 PM
Shorty54
Maybe you can show how you have everything wired?
What is your full set up, radio, receiver etc?
Shad
Old 05-26-2020, 06:43 PM
tachouman
tachouman's Avatar
Thanks for the reply, I downloaded Benedini’s software, and connected the module, it turned out I had an issue with Prop 3 output, I adjusted and reloaded the parameters and it worked. That was a dumb thing I did when got it, somehow I turned off prop 3 without knowing. Anyhow thanks a million for the reply..
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
