Tamyia m1A2 56040
Old 01-12-2021, 10:52 PM
  #251
SERVUS
tune timing to red dots extreme and turn from black dots .
run out of gear box first fine tune abram this is mod section before final assembly
more torque turn faster and top end high speed
yes sorry guys guilty the metal gears .
Old 01-18-2021, 03:34 AM
  #252
SERVUS
Okay gentlemen the 5v Bluetooth Acton begins still waiting on the stereo power amp very small super happy this will mount at rear next to esc board near gear boxes.
I use the Kiss method keep it simple stupid for me.
most powerful tank board is your mobile phone 🤗 cheap any rc tank .
yes the metal gears
Old 01-21-2021, 08:57 AM
  #253
SERVUS
Back to revisit the issues see how this goes with sprockets and metal drive gears mentioned earlier you do it when you can .
see if there is a improvement not mato tracks .
correct gentlemen
now i like the clearence in sprocket and track.
the track guide runs freely which i like .
show soon
really track guide needs to be free running or you get binding have a look inner sprocket no real use first issue also on trsck guide wear even if plastic guide you see binding
outside sprocket perfect
Guide
difference new track the guide horns have more movement
More investigation you find the issue the guide on tamiya is not central .
Right hand track will see left technically the guide it should run free not fixed .
Progress tracks on perfect plumming in bluetooth works a dream just remember you need power stereo amp your set.
sits right in driver hatch for access
I hope you like this.
Old 01-24-2021, 04:52 AM
  #254
SERVUS
All set up works flawless .
Vol up down with phone 100% .
You could place bigger speakers just hold back because it is a tamiya .
Also get phone calls 🙈 okay sorry i used mono amplifier module 5vdc_ 9vdc reason space it has its own seperate volume just turn high use phone for control.
next the red laser mount this next upper turret .
Tested works perfect 5vdc
Old 01-24-2021, 03:59 PM
  #255
Fsttanks
correct gentlemen
show soon
Guide
https://youtu.be/GH222ruJaRo
I have to say I love the look of your custom sprocket. I don’t have any issues with the stock Tamiya sprockets in fact they have proven extremely durable and reliable. But if those custom sprockets were available for purchase I would be tempted just based on the “cool looking factor” they have.
Old 01-27-2021, 03:50 AM
  #256
SERVUS
As you are aware the holes have been precasted why they did not do them only tamiya can answer this ?
your correct they will be okay my issue i had was alignment .
going thru the test it runs as they should be smooth and quiet .
the free spinning and floating centre track
guide not being fixed was the solution for me i will fix sprockets mill out the stock sprockets easy they are marked .
Fit and mount laser how much £4 or €10
manage to show a few tank guys yesterday how fast did the note books and pen come out sure no problem just a sec need to make a phone call lol funny gentleman .
he is not on the tank handy again 😂😂
make me laugh jaurndice good to hear from you get handy call from tamiya development team .
Old 01-31-2021, 05:08 AM
  #257
SERVUS
Tested works well no binding run on some coarse granulate above a fine sand which had issued prior only going on what i have experienced highly recommend doing this and ripped thru it .
not sure if all track guides being solid centres produced a slower track speed i have noticed a vast difference in improvement being on metal tracks next place on Tamiya plastic tracks see what happens .
Old 02-01-2021, 07:47 AM
  #258
SERVUS
just waitng on 8 ohm 2 watt full range stereo speaker .
Old 02-02-2021, 02:58 PM
  #259
MAUS45
MAUS45's Avatar
Nice replacement tracks and drive sprocket!!!
Old 02-04-2021, 02:21 AM
  #260
SERVUS
Thx MAUS45 tracking so smoothe the running gear and if only i could help make some improvements helpful bluetooth your rc tanks my friends a Henglong ,Taigen, Mato , Tamiya nothing will compete with your cheap upgrades making your rc tanks a knowledge weapon it works on 5v dc
Jarndice , adlav will catch up soon tuff year dark indeed feel your pain good to chat.
love tanks also retro radio
Interesting to see mounting in other models .
conclusion on 4 ch transmitter finespec by using a 4 ch switch and y tap into channel 2 you can use the buttons on and off on transmitter functions eg work light , 2nd machine gun , laser pointer gun also main machine gun , and Leaving one more input if you so wish to do .
Old 02-07-2021, 12:07 PM
  #261
SERVUS
running this evening used oem MG button 10 and button 9 to switch to obtain working light and second MG .
as you see it operational.
it is a pleasant surprise .
Old 05-08-2021, 11:02 AM
  #262
SERVUS
Great hear everyone is good spirits the m1a2 will have final speaker upgrade at 8 0hms to see.
painless and jarndice would like to speak with you as Adlav a wish list as time is short for me look forward to your response also Gary .
Old 05-09-2021, 07:22 AM
  #263
jerry325i
Can you take a Tamiya tank display and make a full operating rc tank?Doing this to save money up front and build display first then convert.Just build a Tangen Tiger 1 early.
Old 05-09-2021, 01:12 PM
  #264
fury69
this thread is freaking awesome...
Old 05-09-2021, 05:16 PM
  #265
tankme
Making the static version a running version wouldn't be for the faint of heart unless you end up buying most of the Tamiya parts which would get expensive. Adapting HL parts is an option, but would take some planning and modeling skills. Either way you may end up with a tank that costs almost as much as the full option version. Personally if I wanted a Tamiya Abrams I would buy the full option version. I'm not a fan of the Tamiya electronics so selling them could help offset the cost of the full option kit.
Old 05-10-2021, 05:40 AM
  #266
jerry325i
Thank you for your reply.
Old 05-24-2022, 06:14 AM
  #267
1Randall
I am building the same tank. Now I have built many models in my lifetime and this part has me stumped. I am trying to build up the recoil unit and no matter how I try, I do not understand how part #15 and the little recoil switch go in place one on top of the other, or do I leave part # 15 out.
please help
Old 05-24-2022, 10:02 AM
  #268
Fsttanks
please help
To make it easier for us to answer your questions, what step(s) in the manual are you on for us to reference?
Old 05-24-2022, 10:35 AM
  #269
1Randall
page 26, top half. I think I figured it out, but it doesnt hurt to make sure.
