$7 Modular IR Target
Modular, readily available IR target that I cooked up. It is compatible across all board types, including but not limited to Tamiya, Taigen, IBU, OpenPanzer, and HengLong. Can be powered through any battery that is 3V - 5.5V.
This allows a wide range of batteries to be used, including but not limited to: 1S (3.7V) LiPo, 1S 18650 Li-ion, CR2032/2016 coin cell, 3AA, 3NiMH.
Depending on your application and size needed, you can choose the battery pack and capacity to fit.
Available now at https://www.etsy.com/shop/LegoDEI.
Jeff489 (10-16-2020)
