Tank Keeps Cutting Out
Old 11-23-2020, 12:50 PM
LasvoochTheTiger1Ace
LasvoochTheTiger1Ace's Avatar
Default Tank Keeps Cutting Out
My tank is consistently shutting off as if the power has been unplugged while moving or just on. I checked all of my wires and they all seem to be fine, can't find anywhere it might short circuit or be unplugged. I eventually switched the tamyia plugs to deans but it is still happening. Any of you experience this with your v3 electronics?
Old 11-23-2020, 10:05 PM
Michal_Kaczorowski
Is your battery OK?
Old 11-23-2020, 10:07 PM
I believe so. It is just a 3600 mah nimh battery. It is really purplexing me as i just do not know the cause. I checked all the wire and i cannot find any short circuits. Just was not sure if this was a regular thing for the v3 electronics or not.
Old 11-23-2020, 11:11 PM
Michal_Kaczorowski
Check the battery voltage using multimeter or try another battery. If it's OK, the board could be defective.
Old 11-24-2020, 01:53 AM
jarndice
Location: Hemel Hempstead,Hertfordshire, UNITED KINGDOM
And do check the batteries in your transmitter not only for charge but check they are correctly positioned.
Old 12-03-2020, 03:50 AM
heavyaslead
heavyaslead's Avatar
I have found older batteries, while they may have correct voltage, just brown out when called to power the tank, particularly when drive motors are activated.
Old 12-03-2020, 04:34 AM
Michal_Kaczorowski
Maybe gearbox or tracks are jammed? Jammed wheel or gear could fry the board.
Old 12-03-2020, 06:07 PM
Tanque
Tanque's Avatar
I'd suspect the battery. If the model runs reasonably normally up to the point when it just cuts out I'd strongly suspect battery.
The way most of the model special effects systems operate is when the battery drops below a certain power level the model just stops. I'd suspect charger first and battery second. See if you might be able to borrow a better charger and battery or at least see if someone could lend you a fully charged battery that is known to be a reliable one.
The trick to diagnosing such problems is to establish a point of reference usually with components of known ability to
be able to eliminate one variable after another. Without that it's a tough assignment...
Good luck.
Jerry
Old 12-09-2020, 04:57 AM
gaharit
I wouldn't have thought the problem was the battery if the guys above hadn't explained
Old 12-11-2020, 06:55 AM
heritage19
Did you ever locate the problem, is it working now?
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
