Flakpanzer turret
Old 10-22-2021, 10:24 AM
  #51
ronnie42
Hi all Decided to give put the tanks away for a while due to issues with the flak panzer build. The elevation was playing up but the main issue was a twist in the lower hull . All fixed now and started to fix another problem , changed the travel support to suit the twin flack barrels. Need to check an order thro Paypal as i have not received an order for small chain to fit on 2 tanks before i paint.
No use for this gun travel lock
New support for the AA barrels
Offset , had to redo as i centred it on the bracket first time
A picture of the prototype does not have this.Just made it simple as late war material was in short supply support with no locking feature
Old 10-23-2021, 11:33 AM
  #52
ronnie42
Test 3 quiet traverse servo motor and trying to sync the 37mm cannons with the sounds. Used Audacity music program to make a WAW sound from the single 37mm shot on the Elmod SD card. The clicking noise is the servo arm switching the micro switch for the gun flash, engine on should mask the click.
Smittyburger (10-24-2021)
Old 10-23-2021, 05:15 PM
  #53
manchu9inf
WOW, that is some impressive work!
Old 01-02-2023, 07:18 AM
  #54
ronnie42
Back tidying up this tank, fitted a magnet to close off the rear deck and rearrange the interior. Fuse fitted between gearboxes and a panel underneath the hatches for usb socket,volume, switch and fixed the power plug into the panel side . Used SS woven wire mesh for the grills and put 2 covers on the crew heater fan. New speaker box made as the the old speaker was 4ohm and Elmod board prefers 8ohm, will fit a bigger one soon .It was the only 8ohm speaker I had.
