Flakpanzer turret
Old 11-30-2020, 10:16 AM
ronnie42
Default Flakpanzer turret
HI Building a Flakpanzer Coelian turret with twin 37 mm cannons for a Panther. Can't do videos yet if anyone wants to look its here, you tube then search for Flakpanzer turret test 2
Bought a Takom 2 in 1 Flackpanzer 1/35 kit then made turret 1/16 scale in styrene. Looks like i need 10 or so posts before photos and links etc.
Pnzjgr (12-02-2020)
Old 12-02-2020, 07:59 AM
Pnzjgr
Pnzjgr's Avatar
Sweet can't wait to see it! I'm a Panther fanboy and would love to get a flakpanzer coelian for battling with club members. After you finish yours would you be willing to do another one for me that would work on a tamiya panther? www.desertarmor.com
Duane
Old 12-02-2020, 09:35 AM
ronnie42
Duane
Hi Don't think i am a good enough builder for selling on. This is my first scratch build using styrene sheet . One problem is that it uses servos, Tamiya turret is usually motor / 2 wire for elevation and this does not have a normal recoil function . Recoil is just a continuous servo to imitate the fast flak recoil. I had a search for one before deciding to try and build one, found one selling in Germany for about 100 euro plus postage, can't remember if it was just the turret or fitted out with elevation and flak function. Some more posts and i will be able to show build.
Pnzjgr (12-02-2020)
Old 12-02-2020, 01:45 PM
Pnzjgr
Pnzjgr's Avatar
That's okay. So what kind of electronics you gonna use?
Old 12-03-2020, 09:55 AM
ronnie42
Hi Using an Elmod fusion pro board, easy to setup functions and the app works on a mac. Sounds are ace and you can load custom ones onto the tanks.
Old 12-03-2020, 10:02 AM
Pnzjgr
Pnzjgr's Avatar
That sounds (lol) great! Do you already have the el mod system?
Old 12-03-2020, 01:10 PM
ronnie42
Hi Have 4 in tanks , i like messing about with the settings . Just plug a usb cable in, no taking SD cards out or pressing buttons on a TV remote control. Burned out a servo port on an IBU board and tried the Elmod boards, another plus is the LEDs are protected against reverse polarity and no need to fit resistors.
Pnzjgr (12-03-2020)
Old 12-03-2020, 01:15 PM
Tankster
I definitely agree. Other than my radio, the awesome Elmod board is what maintains my high level of interest in this hobby.
Pnzjgr (02-24-2021)
Old 12-03-2020, 05:18 PM
Pnzjgr
Pnzjgr's Avatar
What other four tanks do you have?
Old 12-04-2020, 03:16 AM
ronnie42
Now i have 10 posts i can show flak panzer build. Made a few mistakes , what do they say measure twice before cutting. Fixed with thin styrene and filler to even up each side, you can see them in the next post. Part one turret sides, cannon elevation and tubes for recoil, the little calculations are rounded down or up as this is not going to be a perfect model.
1/35 to 1/16 is 219% to make life easy used 220% , less than 1% out.
Main turret sides done
The 37mm cannon elevation assembly
Hard part now turret roof and detail
Tubes glued in to support cannon and brass for the 37mm cannons.
Pnzjgr (12-04-2020)
Old 12-04-2020, 03:38 AM
ronnie42
Hi Pnzjgr Sorry missed that post have 5, two Tamiya KTs early and late , Taigen Panther F , Tiger 1 mid and a Panther G Henglong all running Elmod boards bar the late Tamiya.
Old 12-04-2020, 10:59 PM
Pnzjgr
Pnzjgr's Avatar
Wow! That is awesome so far, looks really good! Hope you're having fun doing it. Can't wait to see more.
Old 12-05-2020, 04:13 AM
ronnie42
Part 2 turret top and lining up the cannons, started some brass work and detail on roof. This is when you start to find some faults as it all comes together.
Beefed up cannon support tubes and lining up to glue in.
Brass for muzzle and the shaped part on elevation unit.
Muzzle and shaped barrel support made, trying to copy plastic kit part.
Styrene roof parts fitted and started detailHatches fitted .
Hatches fitted and rain guards made with thin brass rod.Will use BLUESTUFF to make a mould for the smoke/ grenade launcher.
This part will be hard , should be thinking about buying a 3D printer.
Styrene tubes spaced out and centre filled with epoxy then cleanup. Need to catch some parts that are not square or level before painting.
Periscope covers in brass and some plastic coated wire for handles, may strip the plastic off if they look oversize before painting.
Rear hatch and some filler to tidy up some issues, primer always shows up issues.
Pnzjgr (12-05-2020)
Old 12-06-2020, 05:48 AM
ronnie42
Part 3 Tidied up roof and fitted a new flash switch, micro switch died when i reversed recoil servo. Using a leaf switch now as they are robust. Almost have the smooth styrene roughed up to look like rolled armour plate.
Found a gearwheel same size as the elevation drum, made the elevation easy to fit. Continuous servo for recoil
Cut slots in muzzle brake , need a clean up.
Added round sprue to detail the bolts , need to buy some plastic bolt head kits
Hull red on forgot to fix some areas that are not square.
Dark yellow on the parts not needing fixed then filler and hull red again
Pnzjgr (12-07-2020)
Old 12-06-2020, 06:17 AM
Crius
Will both barrels recoil at the same time? I saw a project similar to this where the guy had used a cam mechanism so that the gun barrels recoiled alternatively. It looks really cool, I just wish I could find that now.
Old 12-06-2020, 06:56 AM
ronnie42
Hi Crius No they recoil in unison, found a video of twin 37mm flak and they fired at the same time. Wanted to do the alternate recoil but its a pain as the turret and elevation setup is tight. 2 servos off the same circuit and 180% offset on the servo horns would work but i don't have the space in the turret. Crius how easy is it to post up videos here?
Old 12-06-2020, 09:56 AM
ronnie42
Little video , elevation is on a slider and not as smooth as on a stick , need a longer sound file and adjust to sync with the flash
Pnzjgr (12-07-2020)
Old 12-07-2020, 05:31 AM
ronnie42
Started the camo, its going to be Ambush pattern with the dots or the late green and yellow. Going to try and replicate the interlocking plates , scribe the lines and paint / wash to give the impression. If i do any more will cut the styrene with the notches for the plates. As this is the first scratch build of a turret or hull not too bothered as i now know what is required for building with interlocking plates.
Will end up as one of these two camo patterns
Tamiya dark yellow 2 , light coats want some hull red showing thro in places. Some tape to mask off periscopes
Tamiya dark green 2 , German grey for the barrels
Want to show the interlocking plates, if its a mess doing them at least can paint over again .
Rear green needs a touch up or just say its wear from in and out of the hatch.
The following 2 users liked this post by ronnie42:
bowlman (12-07-2020), Pnzjgr (12-07-2020)
Old 12-07-2020, 08:03 AM
ronnie42
Going to cut out the weld lines , a rub with a file will straighten the cuts out. Should tone down and blend in if i get the painting right.
Marked out started to make the interlocking .
First side almost done , need to look for a file thats the right shape.
Old 12-07-2020, 08:33 AM
ronnie42
Old 12-07-2020, 09:40 AM
ronnie42
Touched up the first side . No problems with the paint match . Much easier doing the other side as you have learned from the 1st .
Some paint on to see how it looks, some more filing to smooth out the weld channels.
2nd side is better found a little file with a wider tip to clean up the cut marks.
Old 12-08-2020, 02:21 AM
ronnie42
Thats the sides done, painted up looks like just one of the weld lines to straighten. Should do the line on the angled plate to tie everything in.
Old 12-08-2020, 06:09 AM
Crius
That looks great, Ronnie. And what you said above is definitely true, you need a 3D printer. We all need a 3D printer. I'd be willing to bet that 30 years from now we'll all have one. Kind of the way it happened with computers, 30 years ago hardly anybody had a computer in their house, now we carry them in our pocket.
and if I can go off topic for just a second, anybody that's concerned about being chipped if you get the coronavirus vaccine, they don't need to chip you. We all have cell phones, and that's all the tracking the government needs. We take our little chip with us everywhere we go.
Old 12-10-2020, 09:53 AM
ronnie42
Tidied up the weld lines and added the numbers, a little issue with some paint under the mask . Once thats fixed some flat varnish to seal the paintwork, the yellow turned out well due to lots of light coats over the hull red
Don't like transfers as they never totally blend in.
Numbers are off a little but did they measure when doing the real thing.
Should do some light deck tan or buff passes with the airbrush to tone down the bright numbers.
Old 12-10-2020, 01:50 PM
MAUS45
MAUS45's Avatar
Wow. great scratch build!!!
