Unused Tamiya MF-01 Plugs?
Greetings!
During the build of my #56016 M26 Pershing I came across an addon Manual documenting an installation change regarding the Lighting Unit in Step 33 as can be seen here:
Original:
The Original uses one 3-PIN Connector attached to CN9.
Addon:
Whereas the Addon now uses both a 3-PIN and a 2-PIN Connector attached to CN9 and CN5 respectively with the latter first needing to have its dummy connector removed.
Now... I also own a #56018 King Tiger which by default has no option for a Lighting Unit, but it does have some unused Connectors similar to the CN5 one - I recall them being called OPT1 / OPT2 ( "Optional"? )
Does anyone know if those OPT Connectors can be used to drive additional features like lights? If so, would they require a similar Light Unit like the one used in the M26 Pershing or could they maybe drive a Light themselves?
Cheers 🙂
Original:
Addon:
Cheers 🙂
Here is another way to power up lights on Tamiya tanks, use a servo hack to switch lights on and off if you have 5 or more channels .Saves messing about with the Tamiya MFU would be expensive if something shorted out or used wrong socket. A little video and a pic of an old servo converted to power lights.
Servo hack ,use wires for motor to power a plug.
Well ain't that some **** 😅
Are you using the servo to mechanically close the circuit or are you hijacking its PCB to do that electronically?
My King Tiger...
Tamiya #56020 King Tiger
...currently uses one of those but it too uses a spare channel of my Receiver and while it technically isn't an issue it kind of is the thought that counts 😆
My King Tiger...
Hi Durahl Nice KT i like the Ambush camo , took me a while to sum up the courage to try painting ambush camo . The servo gears were shot. Removed the motor and soldered 2 jst sockets onto the wires , the servo board just puts out a +ve or -ve voltage depending on the switch position on the Transmitter. Should buy some of the servo switches you use to try out.
