Loose wire in Teigen tiger 1 tank
Hi Everyone
New to the group ,hoping someone can help.
My Teigen tiger 1 tank had for some reason stopped firing and re-coiling upon opening i found a black wire pinched in the turret but i cannot find where it has come from
many thanks
many thanks
If it is a new Tank you should contact the dealer and ask for a serviceable replacement because if you open it up and still cannot get it working you will have invalidated the guarantee.
Most likely it is the 2 wire cable that comes from your turret is not placed in the correct port or came out. The 2 wire cable controls both the recoil and the cannon sound. Check the attached picture and check for slot "E" on your motherboard and insert it as shown. If that doesn't fix it, hit us up on the website and we will take a look for you. Please be aware we are swamped atm and it might take us a bit to respond but most likely that is your issue there as both of those functions are on one cable.
vollenc (02-01-2021)
keefos (02-01-2021)
That my friend is your IR ground cable. You should have either two options to connect that depending on the distributor as sometimes we (IMEX) request special things like different power cables.
- Check your main power cable. At the actual main power switch you should see a red and black cable heading to your motherboard. There might also be a single cable hanging off the power switch, that is connected to the IR turret's ground which allows the firing unit to work. You can compare which cable you have here: https://www.taigentanks.com/products...35669598634151
- Depending on what configuration it came in you might also have that single cable coming from the back of your motherboard. If the tank was in the stock form an IR tank from the factory then TG tends to solder that cable directly on the back of the MB where the power cables are. The effect is the same, just the placement of the cable.
keefos (02-02-2021)
