Torro King Tiger, clicking sound when trying to start
Hi:
I just received my new Torro, RC King Tiger. When I turn the transmitter on, and then swith the tank button to on, it makes a clicking sound. The tank will not start. Any help would be appreciated.
Hi, That sounds (sic) exactly like a flat battery. Did you charge the battery when you unboxed your Tank because the Taigen/Torro King Tiger leaches power from any battery.
Thanks! I charged the battery for like 3or 4hours. Also, when i turn the on switch on, on the tank, it makes a clicking sound the turret moves slightly. After this, it just wont crank. Do I need to charge the battery longer? I guess im just paranoid that it wont work.
I dislike assumptions but I assume that having read the instructions you have "Bound" the Transmitter to the Internal receiver,
The factory supplied charger is a pretty useless lump of metal and plastic which I recommend you change as soon as may be.
Are you in the USA?
If you are then Imex in Florida will be able to supply something more suitable.
Are you in the USA?
Just try to charge 6+ hour again I have same problem in the beginning the battery just flat. after first charge it work fine, contact Torro again if not working they gladly sent you new battery. better put your location in your status so we know where are you.
