Reload this Page >
Help Needed - 2 x ESC into Dasmikro TBS Mini
Old 09-20-2021, 09:11 AM
ai2612
Question Help Needed - 2 x ESC into Dasmikro TBS Mini
Hi - I have been building a basic tank during lockdown using a lot of spares and items I had from previous boat buildings. I am using a Flysky T6 transmitter with channels 1 & 2 mixed to 2 x esc to run motors and steering which seems to work ok on test. I now want to add a Das Mikro TBS Mini for engine sounds and cannot find info on how to connect 2 x esc so that the engine sounds work with both esc, All the info seems to relate to 1 x esc which is on all the wiring diagrams I have found and is understandable, ( Rx chan 2 to Prop1 and the second Prop 1 to Esc ) Can anybody advise where the second esc, Channel 1 on Rx and with bec disconnected should be plugged into. I am hoping to use other connections later for cannon fire and flash - machine gun - front and rear lights and maybe turret rotation / elevation sounds.
Thanks for anyhelp received
Alan
Old 09-22-2021, 12:01 AM
jha13
jha13's Avatar
Hi,
read the Manual:
TBSMini_13_E.pdf
It is very well described.
ESC 1 to Prop1
ESC 2 to Prop2
Old 09-22-2021, 03:24 AM
ai2612
Tx for the info - I had found this manual previously - I can manage the mechanical side quite easily but I am a complete novice on electronics as such and even after reading it several times I am still confused but will persevere. May i ask if ESC 2 goes straight into Prop 2 or should there also be some connection between RX Ch 1 and the unit as well as with Esc 1 ? Thanks for your help
Old 09-22-2021, 09:20 AM
lposter
You could email Benedini (address on his website) and ask him?
He does provide support for his products.
P
Old 09-22-2021, 02:58 PM
tankme
But he doesn't provide support for the DasMikro copy which this person is using.
Old 09-22-2021, 10:11 PM
lposter
Old 09-22-2021, 11:56 PM
jha13
jha13's Avatar
You need a V-cable connecting the second ESC to PROP2 and the RX
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
