Reload this Page >
New Next Gen ELMod Boards Coming Out
Old 12-06-2021, 04:36 PM
  #76
Tankster
Ronnie, what are those two square red buttons on top of your Radiomaster?
Old 12-07-2021, 02:32 AM
  #77
ronnie42
Push switches on top rhs on the Spektrum
Hi Jimster. I like buttons for shot and mg , had to have them .it’s the same mod as on my Spektrum, wired the buttons onto the switch used for weapon sounds. Done the same on the radiomaster, latter I found out that the radio master has 2 spare connectors for pots or switches.😳 This is an easier fix as no soldering inside the transmitter. It’s just buying the correct pre wired socket if I I want more switches or pots😎 and drilling a couple of holes that are clear of the electronics etc
Old 07-04-2022, 07:29 AM
  #78
Michal_Kaczorowski
Originally Posted by ronnie42
Here is a picture of the new board sitting in a Panzer 1 hull and the Fusion pro to give a size comparison. New board has the s-bus and FX for servos and lights plugged in.
Hi!. Did you manage to run the sbus on elmod? If so, what kind of receiver and transmitter do you use?
