Reload this Page >
Tamiya 1/16 Centurion photo build log.
Old 01-18-2022, 10:31 PM
Fsttanks
Default Tamiya 1/16 Centurion photo build log.
This thread is intended to be mainly a simple photo build log to show what ones has to look forward to when building the “New” 1/16 Tamiya Centurion.
A couple of notes. The Centurion is a rather large tank about the size of a Panther but with a much larger turret. I am building the Centurion without side skirts and in one of two themes (undecided yet). Both late 1960 either IDF or Vietnam era Australian. I have one of the new machined 105mm L7 guns being made by RichJohnson (here in the US) on the way and will be working it into the build for fitment testing.
I will endeavor to keep the photo of the build in sequence. If you have any questions about the build or productive comments please feel free to post them.
Box art. Like the M551 Sheridan Tamiya went back to a basic box.
What is in the box of the version I purchased.
Pnzjgr (01-28-2022)
Old 01-18-2022, 10:34 PM
Fsttanks
Build photos continued:
Pnzjgr (01-28-2022)
Old 01-18-2022, 10:37 PM
Fsttanks
Build photos continued.
Pnzjgr (01-28-2022)
Old 01-18-2022, 10:44 PM
Fsttanks
The thin vertical plastic arm linkages are simply cosmetic and I suspect they will be damaged easily. If I was going to attach the side skirts I would have left them off as they would be unseen behind the shirts.
Jumped ahead because I was curious. I had a set of sealed bearings for some of my Tamiya tanks and found that the Centurion uses the same size bearings.
ronnie42 (01-19-2022)
Old 01-18-2022, 11:04 PM
afv aficionado
Hi Fsttanks
Just wondering, do the idlers incorporate a tensioner?
Mal
Old 01-18-2022, 11:15 PM
Fsttanks
Originally Posted by afv aficionado
Hi Fsttanks
Mal
The idler arms and mounts are metal and use the now traditional Tamiya “grove and slot” type of adjustments. The idler wheels are styrene plastic with bearings. Similar to what Tamiya did with the Sheridan.
Old 01-19-2022, 12:23 AM
afv aficionado
Ok, They're a weak point on my Ludwig Cent, very difficult to actually tension.
Ludwig Disassembled with metal upgraded idler
Assembled Ludwig idler
Mal
Old 01-19-2022, 02:35 AM
Panther F
Panther F's Avatar
Thumbs up
Thanks for the good looking build thread, can't wait to jump into that suspension work!
Man... I should have just went with the import version.
Old 01-19-2022, 04:07 PM
Fsttanks
Gearboxes and road wheels.
Note here on the gearboxes. The motors have round shaft, the motor pinion gear uses an “Allen screw” to hold it on. I would highly recommend creating a flat spot on the motor shaft to hold the screw/pinion gear in place and keep it securely attached to shaft. Otherwise is short order the shaft will spin free and pinion gear will not turn. This was an issue several of us had with this set up on the Sheridan gearboxes.
The outdrive gears are the same ones used in the Pershing out drives. I checked them against a spare set of Pershing gears.
Old 01-19-2022, 04:10 PM
Fsttanks
Gearbox covering plate.
Road wheels going on. Note here for those of you looking to add decorative spare road wheels to the front or turret. The Heng Long Challenge 2 wheels are the same size and very close in overall look to those of this kit. Just some very light modifications and you would have very convincing spare wheels.
Old 01-19-2022, 05:20 PM
heavyaslead
heavyaslead's Avatar
Like that outdrive (step 25) similar to Pershing
That's going to run well
Old 01-19-2022, 05:48 PM
Fsttanks
It even uses the Pershing gears in the out drives.
Old 01-20-2022, 02:15 PM
Fsttanks
I actual got more done then shown. The other work was in the area of the electronics. I don’t care for the Tamiya layout as it makes the rear of the tank to heavy. I reworked the battery position and speaker to my liking, so because this is not part of the instructions provided I am leaving it out of the photos. Also gave the tank its first powered run to check the transmission. All worked as expected.
If you want to see my battery and speaker layout let me know.
Old 01-20-2022, 03:09 PM
bowlman
Watching with popcorn
Old 01-20-2022, 05:19 PM
MAUS45
MAUS45's Avatar
Nice to see that the same bearings for the Sherman work for the Centurion!!!
Old 01-20-2022, 07:32 PM
Fsttanks
Started on turret. Note that the turret cargo bins are spring loaded not solidly glue to the turret. Don’t ask me why they are like this I can see no reason why.
Notice the springs for the cargo bins.
Old 01-20-2022, 11:06 PM
Fsttanks
I was asked about the tanks size. Here are a few comparisons with two other Tamiya tanks.
Note: the Centurion is still being built so some wires are not connected to their final systems. Also the 105mm cannon is a temporary until the fully machined one is slightly modified for this tank.
I also have a short video of the basic system test on my Instagram @ fsttanks. Feel free to take a look.
Pershing next to Centurion
Abrams next to Centurion.
Old 01-21-2022, 12:46 AM
afv aficionado
Hi Fsttanks
Springs on the turret bins are really weird. Do the bins open?
Mal
Old 01-21-2022, 03:35 AM
oldwolf75
”…gave the tank its first powered run to check the transmission. All worked as expected. “
Speaking of the transmission, I see Tamiya uses a mix of gear materials. Brass, a silvery metal (steel?) and something black (some kind of tough, low friction plastic?). Is there some reason they do this? Reduces noise? Wears better? Each gear size bought from the cheapest supplier? The contrasting colors looks pretty?
Old 01-21-2022, 04:59 AM
jarndice
Location: Hemel Hempstead,Hertfordshire, UNITED KINGDOM
Nice build,
I was surprised how close in overall size the Centurion is to the Abrams which I had always thought to be much bigger.
Old 01-21-2022, 05:56 AM
Panther F
Panther F's Avatar
Spring loaded turret bins... that explains the gaps I saw on You Tube. Maybe an option to remove them later?
Looks like you're speeding right along on this one!
Old 01-21-2022, 07:08 AM
Fsttanks
I found out why the bins have springs. They need to be moved when removing and replacing the top half of the turret which is held on with magnets.
Old 01-21-2022, 07:13 AM
Fsttanks
Could not tell you why they choose the materials being used. But they work together very well and are reasonably stout.
Old 01-21-2022, 11:06 AM
Fsttanks
Note: 1. I did not photograph each small assembly step this time. But I am sure you can see the process from the instruction manual.
2. The mantle pivot points use bushing that are the small size as the ones intended for the road wheels. Since I had bearings of the same size I swapped out the supplied bushing for bearing. This step is indicated by the photo with the tip of the screwdriver pointed at the diagram.
Wires to right of turret are for the IR bulb not flash. This will be installed when the battle system goes in shortly.
Replaced bushing with bearing. IMO it made the movement of the mantle much smoother.
bowlman (01-21-2022)
Old 01-21-2022, 12:15 PM
afv aficionado
Hi Fsttanks
The odd thing about those springs on the bins is that the bins don't actually lie hard up against the turret, there's a space between them, that you don't see on most models. It was an aspect that surprised me when I was researching for my Ludwig Cent.
Mal
RHS turret bin rear with gap showing
RHS turret bin fwd with gap showing
LHS turret bins with gap showing
king_tubby (01-21-2022)
