Heng Long 360 degree turret wiring
I've recently purchased a new 7.0 Heng Long M-26 Pershing. I also ordered the 360 degree gear ring and wiring kit. I've installed the ring and wiring and the turret now spins 360 degrees but the tank will NOT kill or be killed by another tank. All other tank functions work as they should and yes, the tank was able to kill and be killed before this installation. Does anyone have instructions for this installation, done this installation with good results, or can help in any way. Thanks
I removed the 360 wiring yesterday but left the 360 ring in place. Tank will send and receive hits as before. I spun the turret with the top hull removed so I could watch the wiring. I can do at least two full spins without the wires starting to get tight, So it will remain.
