Heng Long KT (Metal) on Taigen Chassis >
Old 02-22-2023, 02:20 PM
Default Heng Long KT (Metal) on Taigen Chassis
I've got a Heng Long King Tiger (7.0 metal version) coming in. I'd like to replace the HL chassis with the one from Taigen/Torro and just swap everything over. I know the roadwheels are secured differently, but found the fix for that.
As for mounting the hull, Taigen now has the "clip in" feature thats different from HL. Would using magnets to secure them together work to bridge the two designs? If not, what's the best way to connect them?
Any other issues I should be aware of?
I know price wise buying the HL + Taigen chassis will be close to the price of the Taigen, but I dont want Zimmerit + HL slow speed performance is so much better + HL has full control over barrel elevation. For me, the HL is usable as-is without any radio or board upgrades.
Thanks!
Old 02-22-2023, 04:32 PM
Rebellion13's Avatar
Thanks!
Welcome to the forum. On my HL (sold off) I used magnets to secure upper to lower, I glued them in place where the screw holes are, just be careful when lifting the tank by the upper hull, if it separates you will pull out the wiring, especially with a heavier lower......don't ask me how I know this lol. I do know on my Taigen Tiger 1 it has zimmerit but it is kind of like a rubber material that can be pulled off, I did this with the Tiger and tore off pieces to have a battle damage effect. I don't know though if on the King if it is molded into the plastic
Cheers
Wade
Old 02-24-2023, 04:49 AM
Location: Hemel Hempstead,Hertfordshire, UNITED KINGDOM
You can of course buy Countersunk Neo-Dymion magnets that give the ability to screw them firmly but not permanently in place should you wish to remove them at a later date rather than relying upon glue.
Old 02-24-2023, 06:04 AM
This is true. I personally use hot glue, seems to hold rather well and if i need to remove them simply reheat.
Cheers
Wade
Old 02-24-2023, 02:22 PM
I found out the hard way in Texas...hot glue doesn't work in this heat. Had attached an apple mount with it and the glue melted during a battle day. I prefer mechanical connections any day over glue and sometimes both.
Derek
Old 02-24-2023, 04:58 PM
Derek
Good thing I don't live in Texas lol
Old 02-26-2023, 04:13 PM
Thanks for all the tips, I'm going with countersunk magnets.
Rebellion13 (02-27-2023)
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
