Reload this Page >
How do I do twin engine tank control transmitter and reciver wise
Old 12-03-2023, 05:27 AM
[email protected]
Default How do I do twin engine tank control transmitter and reciver wise
What transmitters and recievers suit twin engine tank control with reverse and how can I set up remote control transmitters and recievers to do classic tank control so
2 separate motors left and right, proptional forward ahd reverse and thus turnign on self etc plus other channels to do other thinngs
Its actually fro a prop robot a star wars droid so lookign to also add tools comming out of hatches maybe a whole 25cm lightsabere handle and possibly put a smoke mahine inside etc.
MNost controls I see only have a 0-100 forward throttle not forward and reverse and def no twin engine set ups.
Looking to get second hand gear off ebays etc
Please advise
Old 12-03-2023, 09:49 AM
pitstain
other than the built in sounds a Clark or IBU tank control board paired with a 4 or more channel stick radio (with analog trims) should suit your needs perfectly, it will have outputs for cannon and machine gun flash as well as turret rotation (head) barrel elevation (body tilt) recoil (maybe lightsaber ejection) smoke control, etc. I am sure some other will chime in, possibly with a board where you can upload your own sound files.
Old 12-04-2023, 06:42 AM
Max-U52
Why don't you just use a sabretooth?
Old 12-04-2023, 10:19 AM
RC_BobM
Sounds like you need a 2 motor Electronic Speed controller. You also need to know if the motors are brushed (old tech, common) or brushless (new technology) - this will determine what type ESC you need. Also the amps and voltage rating of your motors.
A two motor set up such as a tank (driving tracks) will use 2 channels on the receiver - one throttle and one for turning (rudder). So as a minimum you need a 2 channel radio and receiver. Most radio/receiver come with more channels than 2 (3, 4, 6 10 etc).
As mentioned the Sabertooth line are excellent and easy to use - for brushed type motor.
B
Old 12-04-2023, 12:29 PM
tankme
Sounds like it might be out of his price range (second hand eBay) and the Sabertooth won't control smoke or "tools coming out of hatches". Any tank controller would work, but I'm staying out of the rest of this conversation as the next set of questions will be how do I wire it all up. Unfortunately I'm not here to engineer someone else's entire R2D2 project.
Old 12-05-2023, 06:45 AM
Max-U52
Agreed. I already have a couple ideas using an old taigen tx/mfu but this sounds like a project I'd probably be better off not getting involved with. I already have enough projects on the shelf as it is. Besides, the guy only has two posts and he hasn't been back since he started the thread.
