My Heng Long Abrams Build >
Old 05-18-2024, 10:53 AM
it was easier to use their term than say the thingy that hangs off the other thingy in the back of that thingy
Old 05-18-2024, 01:01 PM
I guess this settles the suspension arm color question
Old 05-21-2024, 11:19 AM
Progressing steadily, got the lower hull back together, slip ring has been installed in the turret along with the CROWS and painting has started on that
Davepriddy14 (06-08-2024)
Old 05-24-2024, 12:32 PM
The following 2 users liked this post by skyowa:
Davepriddy14 (06-08-2024), tankme (05-24-2024)
Old 05-28-2024, 09:14 PM
How to hide the hull seam, please note the 1/16 scale screws, thinking I'll just fill the heads. Also started weathering without an actual clue
Old 05-28-2024, 10:42 PM
  #31
The screws on the tow bar are T shaped pins in real life. So you could literally sand them down flat with a Dremel and fill the tops. I think I ended up using two different sized of styrene rod and gluing them together to make some pins, but in the future I will 3D print the pins. Making a simple T pin in the slicer is pretty easy using the Orca slicer.
skyowa (06-01-2024)
Old 06-03-2024, 03:32 PM
  #32
Pah co chu puk's Avatar
Looking good!
For your tow cable mounts, do a "T" shaped piece for the front and then heat and bend a sheet of styrene for the back mount. I did my weathering using real clay dirt. It can be washed off if I don't like a spot, and then re applied. Clay soil in a cup with 1 drop of dish soap and some water. Add water as needed.
None of the weathering on my Abrams is paint.
The following 2 users liked this post by Pah co chu puk:
Davepriddy14 (06-08-2024), tankme (06-04-2024)
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
