Reload this Page >
You *can* grind down the Heng Long T-34 headlight
Old 02-19-2024, 07:15 PM
maillemaker
Default You *can* grind down the Heng Long T-34 headlight
So the LED on the Heng Long T-34 sticks out of the face of the fixture like a giant zit.
I filed it down and the LED does still work. It doesn't light up the entire lens as it should, but the LED still works. You could fashion a blackout slit cover out of styrene or modeling clay or whatever and it would work though.
I am replacing it with a metal replacement with a proper headlight lens, and a warm yellow micro LED.
But it was a fun exercise.
Steve
Old 02-19-2024, 08:13 PM
tankme
Yeah, as long as you don't grind it down to the metal posts it will still work. I will hit them with some 1500 or 2000 grit sandpaper and then some rubbing compound if you want them to be really clear after cutting them down.
Old 02-20-2024, 01:10 AM
Max-U52
Steve
Have you already got the metal headlight? I bought about 20 of the Taigen T-34 headlights to use on trucks so if you need one, send me a PM.
Old 02-20-2024, 07:44 AM
maillemaker
Thanks, yeah I bought 5 of them. They are pretty cheap. It's the tiny warm LEDs that are $15 a pop!
Old 02-20-2024, 10:16 AM
Max-U52
The ones I got came with the LED but when I need an LED I usually go for the 3 mm warm white.
Old 02-20-2024, 11:32 AM
maillemaker
Mine came with an LED also but it is far to bright/white.
Old 02-20-2024, 12:08 PM
Max-U52
PM your address and I'll send you a few 3mm warm white to test. I think you'll be surprised, and I got 100 of them for about 8 bucks, but that was a few years ago so they might be a bit more now.
Old 02-27-2024, 06:31 AM
maillemaker
LOL I ordered "3" warm leds but turns out each package was 10 pieces. So I now have a boatload of tiny warm LEDs.
Old 02-27-2024, 06:40 AM
cleong
Well you can put them on three more new tanks then!
Old 02-27-2024, 10:25 AM
Max-U52
You also have some 3 mm warm white LED's on the way.
