AEC MKIII SCRATCH BUILD 1/16TH
#76
RE: AEC MKIII SCRATCH BUILD 1/16TH
It can run pretty fast but I only use that power to get over the battlefield hills and obstacles. If I were to dial down the max speed, she would not have the power to climb.Now, If I could only afford the electronics to make here battle ready.
DH
DH
#77
AEC is borrowing the Shermans electronics and TBU for a battleday on the 25th of March. You can all blame KSOC for getting me to tear up the Sherman. Lots of wires to fit in such a small space. Reminds me of the old RC submarine days.
Cant wait to see how it does.
Pictures Tomorrow.
DH
Pictures Tomorrow.
DH
#78
I guess if I don't want tire marks on the top of my tank, I better battle on the Allied side next battle
See you on the 25th
Kevin O
<S.C.A.T.>
See you on the 25th
Kevin O
<S.C.A.T.>
#79
Let see how it runs first. Got all of the electronics to fit inside. Very little room for the speaker or any sort of box to make the sounds stronger. I will play with that over the weekend.
It does however, take hits and fire shots now.
And the Tamiya Pershing owners think their tanks are tight:
#80
AEC now has Full Option Tamiya electronics. I plan on running it this Sunday at our battlefield. Weight is becoming an issue so the car sits a bit low. Should be able to drive circles around the other traditional tanks.
Used my Sherman electronics and installed deans connectors where needed. I can now swap electronics between vehicles in about 15 minuites.
Look out guys.........
#82
http://www.wsdeans.com/
Lots of sizes with a positive solder on connection. (No crimping) Use them on all my submarine connections. Even wet conditions.
