Broken Bulldog Muzzle
RE: Broken Bulldog Gun Nozzle
If you decide to keep it instead of returning it or waiting for a claim, you could glue it together with medium CA(superglue gel). Let a little ooze out(or put some on any cracks with a toothpick after its glued). When it dries hard you can sand it down with a sanding stick to shape and the CA will fill the gap. You can tjem paint over it with something close to the color.
IMO I wouldn't send the whole tank back. Try to get the seller to send you a new barrel if possible. That's an easy fix with CA. I know, I've done it already!
My Feedback: (24)
Thanks. I will give it a shot and fill the seams with hobby putty, then sand and repaint. By the way, very nice driving tank. That S&S 10 speed makes a huge difference. Can't wait until Mato have the other custom limited edition tanks back in stock.
That looks great. I'm glad you were able to salvage it and make it look right again.
On a similar note, the plastic of these tanks can also be glued with regular plastic model cement. So if you want to add on other details like scratchbuilt parts, etc. and prefer the slower working time of plastic model cement, then you're good to go.
I guess the tank is made of a heavier styrene(?).
-Harq
-Harq
Oh? That's good to know. I was unaware that the T-34/85 was constructed of a plastic similar to the Heng Long tanks.
[sm=thumbs_up.gif]
-Harque
[sm=thumbs_up.gif]
-Harque
ORIGINAL: Richard L.
Yes, I did use plastic model cement to glue most of the little parts onto my T-34 tank.
Repaint that sucker!
Is it painted already in a sort of semi-gloss paint (like the HL's) or is that just bare plastic "molded in color"?
In any event, you just can't drive that beast around the way it is, as just another WSN T-34 clone...
Different decals can be had from other versions of the static Trumpeter kit.
-Harq
-Harq
Yep, I think the T-34/85 is made out of similar plastic, and model glue worked like a charm.
My Feedback: (24)
The tank itself has a coat of flat paint from the factory, and the markings are painted on by the factory. The flash from the camera made the tank more glossy than it actually is. The things that are just bare plastic molded in color are the oil drums and other small detail pieces. I will weather the oil drums and tone them down a little to remove the shine.
That muzzle breakage is EXACTLY what happened to mine. I also glued it back, sanded, and painted. I've broken it again once since then, driving offroad. As long as the parts aren't lost, everything's OK......
My Feedback: (24)
ORIGINAL: Harquebus
