Best FM Radio for a Tamiya leo2A6
I'm looking for suggestions for a 6 channel radio for a Tamiya leo2A6 tank. I wanted to get 6 channels in case I want to add some extra functions and I wanted to use FM for rejection of interferance and better range. I'm leaning towards the Hitec Laser 6 mainly because I don't see much else out there in 6 channel FM and 75 Mhz. Anyone out there have an opinion on this? What are most other people using?
Thanks.
Thanks.
RE: Best FM Radio for a Tamiya leo2A6
I use a Futuba F-14 40mhz FM radio. That works great and a super benefit, is that it can be extended with a lot of extra functions.
regards
Steen
regards
Steen
FL
You also could use the new spektrum 2.4Ghz 6 channel radios on surface. Since it is 2.4Ghz you can use it for air or surface. Whatever 6 channel you get make sure you order the necessary parts to make the throttle a spring return instead of the ratchet stick all come standard with. I've converted all my Futaba 4YF's, and the parts are usually less than $2.
NC
Hi Hobbymaster,
just wondering if you can point me in the right direction to order those parts to make the throttle a spring return? I have a futaba 4ch "attack" radio i need to do that to...
Thank-You
Thank-You
ORIGINAL: hobbimaster
Thanks for the reply. I am looking at the Futaba 6YG. Hobbimaster, I'm also very interested in where one could get the parts to change the throtttle to a spring return.
