Reload this Page >
Broken Heng Long Tiger Tank
Old 05-19-2007, 05:55 PM
leigh_verner
Default Broken Heng Long Tiger Tank
Hi there i have bought a heng long tank but it is broken .It starts up but there is no control after that i need to know some of the wiring circiuts because i am lost can anyone help me ? need pictures please. I May need a picture of the main rectangular plug circuit.
Old 05-20-2007, 03:57 PM
pattoncommander
pattoncommander's Avatar
Default RE: Broken Heng Long Tiger Tank
check your abc switch on the bottom to be sure your on the right frequency. This has happened a couple times on a couple of mine, where the switch got knocked off the setting that correlates to the controller.
I have a similar prpblem with my Pz III that maybe someone can post an idea. Often the same problem and the switch is OK. Sometimes I have to restart before I have any control or movement.
Old 05-23-2007, 11:39 AM
leigh_verner
Its a differnt model it runs on a crystal, so it cant be that....
Old 05-23-2007, 01:40 PM
BIGGrobb
Have you thought maybe about checking that the crystals are the same in the transmitter and the insides of the tank?! Before you go changing any circuitry, you might like to think about checking to see if your transmitter is actually sending a signal and if the tank is transmitting a signal.
Old 05-24-2007, 11:04 AM
leigh_verner
the tanks engine sound runs and the smoke runs but it will ntot do anything else ,could it still br the crystals?
Old 05-24-2007, 11:31 AM
The_Stuff
The_Stuff's Avatar
try holding the remote really close to the tank. if it works its the antennae. dose the machine gun fire or the cannon fire work?
Old 05-24-2007, 01:47 PM
leigh_verner
no the cannon and the machine gun does not work.
Old 05-24-2007, 02:57 PM
swathdiver
swathdiver's Avatar
Pop in your spare board. If that doesn't work, try your spare transmitter. You do have spares don't you?
Old 05-24-2007, 04:24 PM
The_Stuff
The_Stuff's Avatar
lol james. nice.
umm it could be the controller. seeing as it will turn on and off the tank but nothing more. i assume it could be just a bad connection. but it is a bit weird. I just upgraded my pershing to S&S and it was very limited on range. found out that there was a bad negative wire solder and thats what limited it so bad. maybe there is a bad solder?
Old 05-24-2007, 04:32 PM
leigh_verner
It will turn the tank on but it wont turn it off after it is on ive tried changing all the contoller and everything no having much luck
Old 05-24-2007, 06:16 PM
The_Stuff
The_Stuff's Avatar
its sounding like a bad board. your sure the battery is all charged up etc? if it is i think the board is bad. james might have hit the nail on the head here.
Old 05-25-2007, 10:44 AM
leigh_verner
do you know anywhere i can get one for a smoke and sound with crystal?
