tiger turret
tiger turret
Hello, I'm very new to all this !! could someone please show me the best way to take a HL tiger turret off, I want to do some painting and ajustments. Any comments or idea's would be helpfull, Cheers.
RE: tiger turret
Hi there, this is the best place to learn how to take apart and modify your tank step by step
http://www.tankzone.co.uk/pages/hl_upgrade_guide.htm
1 Post
RE: tiger turret
Yup, follow the instructions in the thread above to get it into 2 bits, then you'll see that the turret ring (with the teeth on it) is screwed into the turret. Undo those (3 on the Tiger if memory serves), then you can pull the turret away from the body to get to the 5-6 screws that hold the 2 halves together.. easy peasy
RE: tiger turret
Yes look at tankzone. Basically you need to remove the tracks first so you can access the screws to take aprt hull. Once done you can them access screws to remove turret and then you can take turret apart! Easy! ;-)
RE: tiger turret
another quick question for you guys: is it fairly easy to turn the main gun over so the turret mg, etc. is in the right place ?
1 Post
RE: tiger turret
ORIGINAL: chinni
