Reload this Page >
8.4 Volts with HL electrics
Old 06-18-2007, 03:10 PM
shenlonco
shenlonco's Avatar
Default 8.4 Volts with HL electrics
Well i hooked up the HL S&S electrics in my 1/24 abrams and it seems to work just as cool as it did on 7.2 volts looks like the boards can handel the extra cell...... I let the 7 aa batteries sit for like 15 min after full charge so the voltage drops off I did not want to risk peak voltage that may be to high and do some damage .....then i used them and it worked out fine.
Old 06-18-2007, 04:08 PM
Aslvrfrost98csvt
Aslvrfrost98csvt's Avatar
Default RE: 8.4 Volts with HL electrics
thats good to know i just ordered some boards from mato so my hl/Vs conversion should work fine now
Old 06-18-2007, 05:12 PM
shenlonco
shenlonco's Avatar
Hi just a note my abrams was like 4 years old and used alot... the motors did not run the same and i could not trim it out with the HL radio...and i threw my spring out that i took out of it's gear box.... So i had to use a piece of silicone fuel line and go crazy taking it in and out until i finnaly found the right size i needed now it works....So hope you kept your spring!!
Probably most likely just that it was so old and used but i did not want to order a new one for $18.00 plus shipping from toyeast!
Also i relocated the sound vol controle i drilled a big hole in the last AA holder and mounted it flush in the top.
Old 06-18-2007, 05:23 PM
Richard L.
My Feedback: (24)
Richard L.'s Avatar
Now do the same test with a 9.6V battery pack to see if HL S&S electronics can handle it without smoking
Old 06-18-2007, 05:26 PM
shenlonco
shenlonco's Avatar
Here are the photos of it.
ID:	706581   Click image for larger version
Old 06-18-2007, 06:37 PM
Aslvrfrost98csvt
looks like you positioned the boards differently from your leopard 2 any particular reason
Old 06-18-2007, 07:02 PM
shenlonco
shenlonco's Avatar
Yep this is the only way it fit's in the abrams
Old 06-19-2007, 03:26 PM
fv432
Banned
shenloco ive put 12volts through mine 1/24 leopard now runs in my 1/25 jagdpanther no mods no smoke goes flipping quick though been running like that for last 2 years on original board
hope this helps
ROB
Old 06-19-2007, 03:37 PM
shenlonco
shenlonco's Avatar
Your telling me you run 12 volts through the HL smoke and sound electrics with no problems?
Old 06-19-2007, 03:40 PM
fv432
Banned
oops sorry mate no its the older hen long non s+s sorry for the confusion
Old 06-19-2007, 05:55 PM
Aslvrfrost98csvt
fv you know shen did a hl conversion in his Vs the hl boards i dont think will handle 12 volt especially the older non s&s boards
Old 06-20-2007, 09:51 AM
fv432
Banned
they are the old hen long boards from there 1/24 leopard the one that looks similar to vs
Old 06-20-2007, 12:42 PM
Aslvrfrost98csvt
oh shen and i are using the 1/16 s&s boards in our Vs me in my leopard 2 and him in his abrams and leopard
Old 06-30-2007, 04:26 AM
the shredder
Have any of you ever tried going the other way? an entire vstank electronics set up in a hl so you could do ir battles with the 1/16 tanks? I myself want to try this very badly. I figure the motors & gear box from the hl are the only things you need to keep right?
Old 06-30-2007, 07:25 AM
shenlonco
shenlonco's Avatar
Hi It wont work because there is no throttle trim on VS tanks in there gear box they have a slipper clutch that makes both motors go the same RPM so the tanks drive straight.
Old 07-05-2007, 07:19 AM
the shredder
Does anybody know the vstank IR wavelength? I want to build some targets in a bridge & in some buildings for my battlefield.
Old 07-06-2007, 08:31 AM
leigh_verner
Im Running 6v through my HL electronics , Works great with low risk of killing the board
Old 07-08-2007, 02:02 PM
tiger205
hi richard. i have, my T34 runs with heng long smoke and sound electrics,everything including the smoke unit(modified)works well, and i use the 9.6v battery pack that came with the tank, i decided to use this because of the space needed for the smoke unit, see pictures, i can say, i have had no problems at all,with electrics burning out, i may even use a 9.6v battery in my tiger, i gave it a quick try, and the tiger run fantastic, it did burn the smoke unit out after 20min's of running about terrorising the dogs.will try it out properly in the tiger after i have put some motors with 3 times the torque output in
ID:	718355   Click image for larger version
ID:	718356   Click image for larger version
ID:	718357   Click image for larger version
