88 Bunker
Old 06-23-2007, 05:52 PM
dacostasr
dacostasr's Avatar
Default 88 Bunker
Saw one of these in a picture..thought it would make a nice addition to the battlefield. Only problem is I don't have an 88 to put in it. I'm going to make a mock 88 with balsa and throw some heavy camo netting on it
Later,
Dennis
ID:	709461   Click image for larger version
ID:	709462   Click image for larger version
ID:	709463   Click image for larger version
Old 06-23-2007, 09:26 PM
dacostasr
dacostasr's Avatar
Default RE: 88 Bunker
A little more progress...
Artillery crewman ranging....
Later,
Dennis
ID:	709588   Click image for larger version
ID:	709589   Click image for larger version
Old 06-23-2007, 09:29 PM
Hotice17
nice bunker! what material your using?
Old 06-24-2007, 07:14 AM
ArmChairGeneral
ArmChairGeneral's Avatar
This looks like it will be a good one, I have been thinking of making some AT guns, pak 45 and 88 would be cool.
Old 06-24-2007, 07:45 AM
dacostasr
dacostasr's Avatar
Thanks guys...
Material is 1.5 inch house insulation...and plywood base. I'll be adding some joint compound to give it some texture and sand.
Later,
Dennis
Old 06-24-2007, 05:19 PM
dacostasr
dacostasr's Avatar
Made an 88 today...it is sort of scale...with camo netting you won't notice...barrel is from my tiger I. The rest is aircraft ply, and craft wood, the shield on front is from a plastic DVD case.
Later,
Dennis
ID:	710053   Click image for larger version
ID:	710054   Click image for larger version
ID:	710055   Click image for larger version
ID:	710056   Click image for larger version
Old 06-24-2007, 05:22 PM
Hotice17
Old 06-24-2007, 05:26 PM
Hotice17
is that a scratch built 88? very hard to find the material here to scratch built [:@].in what scale are you plaining to build?
Old 06-24-2007, 05:57 PM
dacostasr
dacostasr's Avatar
yep scratch built...the only thing I didn't build was the barrel...that was the orignal tiger I barrel (my tank has a metal one). The rest I just drew after looking at some pics on the net and the verlinden catalog and just cut them on my scroll saw...no measuring...so it is about 1/16 scale . Looks right in the bunker.
I used 1/8 inch aircraft ply...but I'm sure any ply or even very thick hard cardboard would work.
Later,
Dennis
Old 06-24-2007, 06:04 PM
Plastic scouser
Looking Good Dennis [sm=thumbup.gif] and the speed you get things built is unbelievable i just don't seem to be able to find the time and when i do the missus moans[:@]
Cheers Ian
Old 06-24-2007, 08:35 PM
ArmChairGeneral
With the amount of building Dennis has we will soon be able to do a remake of Godzilla
Old 06-25-2007, 12:13 PM
dacostasr
dacostasr's Avatar
More sandbags...took me about an hour to make. I have to work on size consistency.
Wooden blocks in the background will be shell crates.
Old 06-25-2007, 04:36 PM
dacostasr
dacostasr's Avatar
accessorizing...lol.
ID:	710818   Click image for larger version
Old 06-25-2007, 07:15 PM
Skald
Man you get things done quick!
Do you have kevlar elves helping you in your shop?
Old 06-27-2007, 09:04 AM
dacostasr
dacostasr's Avatar
Base coated...black. Drybrushing today.
Later,
Dennis
Old 06-27-2007, 01:12 PM
ArmChairGeneral
Nice heavy look, so you base coat black and then weather it with a grey?
Old 06-27-2007, 04:58 PM
dacostasr
dacostasr's Avatar
Yep...usually drybrush 3 shades of grey for concrete and a little tan.
AC/DC inverter WORKS!!! We WILL have SMOKE!!
Old 06-28-2007, 07:19 AM
dacostasr
dacostasr's Avatar
Nearing completion...
ID:	712775   Click image for larger version
Old 06-28-2007, 07:26 AM
ArmChairGeneral
Bunker looks great ! You've got the foam building technique down pat, the 88 gun needs to be panzer grey or dark yellow with some camo on it, I would recommend the dark yellow to make it more camera and spectator friendly. In the future we can add a IR kit from tank hobby and a 2 ch radio to make this active.
Old 06-28-2007, 07:35 AM
dacostasr
dacostasr's Avatar
I think I have some panzer grey left....but I think you're right dark yellow would make it stand out...that light grey is primer. Hopefully our local hobby shop will have the yellow...if not I know niagara hobby does.
I just checked out the tank hobby page...that is pretty cool...that would definitely be a scary bunker with IR.
Old 06-28-2007, 07:54 AM
killick64
killick64's Avatar
Just out of curiosity, Dennis -- what did you use for an "88 Round" ......????
Paul McD
Old 06-28-2007, 08:27 AM
dacostasr
dacostasr's Avatar
The 88 round is a 1/4 dowel I sanded to a projectile shape.
Old 06-29-2007, 08:30 AM
dacostasr
dacostasr's Avatar
Next little project started...
http://www.rcuniverse.com/forum/m_6050008/tm.htm
Later,
Dennis
Old 07-14-2007, 06:16 PM
dacostasr
dacostasr's Avatar
A little more progress....still don't have paint for the GUN...but made some ammo crates...washed the bags...made some casings from 1/4 brass tube and got a couple more guys for the crew.
Later,
Dennis
ID:	722829   Click image for larger version
ID:	722830   Click image for larger version
ID:	722831   Click image for larger version
ID:	722832   Click image for larger version
Old 07-16-2007, 09:18 AM
ArmChairGeneral
Nice looking Dennis, I look forward to machine gunning the crew and over running the position
