Reload this Page >
"In The Mood" M4A1 76mm Build
Old 02-10-2008, 01:34 PM
  #51
edoubleaz
edoubleaz's Avatar
Default RE: "In The Mood" M4A1 76mm Build
Final chapter.... In battle!
ID:	875016   Click image for larger version
ID:	875017   Click image for larger version
Old 02-10-2008, 03:37 PM
  #52
pcomm1
Outstanding and I hope they played Taps for you (the military bugle call).
Old 04-02-2012, 06:49 PM
  #53
edoubleaz
edoubleaz's Avatar
Default RE:
Wow, I am feeling the years now as I update a build page after 4 years!!!
In the Mood has seen dozens of battles and was even sold to members of DAK before finding its way back to the C.O.s bench. Now that the hobby has caught up with what I wanted to do with it originally, it is time for a tank overhaul!! I stripped the innards and will add the M51 guts with recoil.
Of course..... VVSS
ID:	1746159   Click image for larger version
ID:	1746160   Click image for larger version
Old 07-02-2012, 05:47 AM
  #54
edoubleaz
edoubleaz's Avatar
Default RE: RE:
Not much progress on "In The Mood" but I added a picture of my latest project.... Baby Liliana learning the tank ropes.
Liliana learns the ropes 2 by edoubleaz, on Flickr
Old 07-02-2012, 09:50 AM
  #55
yellowshaker
yellowshaker's Avatar
Default RE:
NICE! Congrats brother!!!
Old 02-24-2016, 12:52 PM
  #56
edoubleaz
edoubleaz's Avatar
Many of you may have guessed by now I am scratching and clawing more hobby time from my HUSBAND/DAD/WORK life and dusting off old projects to get them on the field. Much of this comes from daughter in pre-k, wife working at home and shooing me to the garage, and work settling into almost normal hours and staffing. I am riding this pony into the ground as in a few months it will be too hot to work in the garage.
Several of these zombie posts are meant to show that these projects really have a life of their own. Tamiya based vehicles run for years and years and this one has almost 9 lives. It has been sold twice, refurbed three times, and now finally will be rebuilt from the ground up. The HVSS lower is gone.... The Nick Aquilar resin hull warped uncontrollably in the AZ heat and is gone.... Tamiya Sherman guts moved in to my Ambulance M113. All that is left is the original Nick Turret now modified with Tamiya recoil.
To start I dusted off my last remaining MATO cast hull and pulled apart the HengLong 105mm Sherman turret I scavenged for my Dugster project. The lower half will replace the bottom of the Nick Turret.
IMG_0303 by Ethan Dunsford, on Flickr
I cut off the Bustle and removed some locating pins from the lower.
IMG_0304 by Ethan Dunsford, on Flickr
Fitted the lower to the hull and made sure the traverse unit meshed.
IMG_0307 by Ethan Dunsford, on Flickr
IMG_0305 by Ethan Dunsford, on Flickr
Mated the parts and like the look so far.
IMG_0306 by Ethan Dunsford, on Flickr
Old 02-24-2016, 04:44 PM
  #57
RichJohnson
RichJohnson's Avatar
YeH those urethane hulls need to be braced with plexiglass inside. I do it on the sides and across too.
where do you get the urethane primer. I have that problem with paint rubbing off easy.
Old 02-24-2016, 05:24 PM
  #58
edoubleaz
edoubleaz's Avatar
I used a Primer from MrHobby that is meant for Resin. Holds pretty good! A picture of it is on the first page of the thread.
