henglong tiger 1
Old 02-19-2008, 02:24 PM
brel
Banned
Default RE: henglong tiger 1
ORIGINAL: Panzerfaust77
Yikes! You need get an oil-shield over those gears! That PCB is covered with oil [X(]
It is grease and yes you are right I do need to shield the PCB
Old 02-19-2008, 06:34 PM
brel
Banned
I am in the process of making a shield for the pcb it will be fitted tomorrow when the epoxy resin that I have used to fill the holes in the bottom of the hull dries. all I have to do is decide where I am going to put the smoke switch and sound pot.
here is a link to my topic about where I put the main power switch.
http://www.rcuniverse.com/forum/m_70...tm.htm#7075490
Old 02-20-2008, 04:10 AM
Panzerfaust77
Panzerfaust77's Avatar
ORIGINAL: brel
I just used a bit of cardboard wedged between the PCB and the gear housing. Works fine.
Old 02-20-2008, 06:47 AM
blitzkrieg65
blitzkrieg65's Avatar
ORIGINAL: brel
ORIGINAL: brel
I find it easier to put the battery in with the battery's power connector end towards the rear of the Tiger tank, as shown in the picture
Cheers but your power cable is waaay longer than mine so I cant' do that.
I took the tank apart and desoldered the wires from the switch and PCB undid the knot and resoldered the wires. Because the battery in the photo is from an old rc car that no longer works so I had to lengthen the tanks wires.
the wires on the black battery are shorter than the wires on the stock HL battery as shown in the picture, but since I lengthened the power lead I have moved the main power switch in to the turret
Yikes! You need get an oil-shield over those geas! That PCB is covered with oil [X(]
Guys, Here is one solution!
http://www.rcuniverse.com/forum/m_67..._1/key_/tm.htm
The Blitz
Old 02-20-2008, 07:03 AM
brel
Banned
Blitz Thanks for the info.
Old 02-20-2008, 04:44 PM
  #31
brel
Banned
PCB guard made and fitted
Old 02-22-2008, 04:11 AM
  #32
1002frans
HAHA,Getting my kt t mrrow,anybody intressted in henglong crap they r in the trashcan,ive burned them poured some petrol over them made a bonfire 3000rand down the drain
Old 02-22-2008, 07:24 AM
  #33
wackywheelz
wackywheelz's Avatar
...obviously HL isnt for you then
Old 02-22-2008, 11:19 AM
  #34
1002frans
Wweelz you r right my freind gettin my kt from tamiya t morrow.Rather 1 decent tank then a shelf full of crap,cant get the upgrade parts here ,mailed henglong,no reaction from them.if you stayed here you could have had the crap for mahala[:@][sm=drowning.gif][sm=punching.gif][sm=angry_smile.gif][sm=spinnyeyes.gif]waste of money
Old 02-23-2008, 04:31 AM
  #35
wackywheelz
Thats your opinion, I have no idea of where you sit geographically but if you're flying to get deliveries it must be pretty remote. Heng Long deal with distributors/retailers, not end-customers. Hence you deal with the retailer/ebayer and not the factory.
Old 02-23-2008, 08:44 AM
  #36
YHR
YHR's Avatar
ORIGINAL: 1002frans
Most of the guys on this board who have Heng long have been able to turn them into satisfying RC models. Sorry we were not able to help you. As a matter of fact you may be the only person this forum has been unable to help. All the upgrade parts are avaliable online at many different retailers as well as avaliable on eBay
Good luck on your Tamiya adventure. I hope for the King Tigers sake, nothing breaks.
Old 02-23-2008, 09:00 AM
  #37
YHR
YHR's Avatar
ORIGINAL: brel
Here is another option as well. I installed a bulkhead between the motor and the electronics. A thin sheet of styrene is then used to cover the entire gearbox section of the tank. It is glued at the bulkhead end and then tucked underneath the plastic I beam glued to the front.
Old 02-23-2008, 09:35 AM
  #38
jakeand
jakeand's Avatar
Hi YHR
Very clean and tidy installation you got there[sm=thumbs_up.gif]
Regards
Jake
Old 02-23-2008, 10:30 AM
  #39
brel
Banned
nice work on your tank YHR
Old 02-23-2008, 10:42 AM
  #40
YHR
YHR's Avatar
Thanks.
While waiting on new releases I turned my attention to the interiors of the tanks I own. I have reworked most of them to clean up the electronic install to this level of neatness
Old 02-23-2008, 12:41 PM
  #41
1002frans
WACYWHEELS,Istay in jhb south africa,this was a deal between me and a friend,he brings in stuff from hongkong cowboy,my flight ticket cost me nothing only the airport tax .Iworked for s african airways can fly to werever i want.WE had a deal and i saved over 600r in shipping costs.i think henglong has got a responsibility towards there customors as we put bread on there tables.the shop were i bought the tank cant help me with the gearbox as he doesnt do spares,and he hasent got anymore in stock,nobody here operates tanks,mostly airoplanes helo"s and cars and some scale boats but not mutch.I am also involved with the scale model boats got a active club in pretoria.thanks for your reply frans .GOT THE KING TIGER 2 DAY,MY FRIEND HAS GOT THE SHERMAN TIGER 1 AND THE PERSHING ,HE"S RUNNING METAL TRACKS ON HIS MODELS,AND HE DRIVES THEM HARD NO PROBLEMS.STILL GOT THE TIGER 1"S WILL SELL ONE OF THEM
Old 04-05-2008, 12:49 PM
  #42
1002frans
HI,Hope ypu can help me why is the torsion bars on the tiger and the king tiger not in the same line one set to the front the other side to the rear please explain thanks frans
Old 04-05-2008, 10:54 PM
  #43
pzrwest
pzrwest's Avatar
Because that is the way the original tigers and KT's were built, the panther was also that way I believe
Old 04-06-2008, 12:44 AM
  #44
1002frans
Thanks,but what i would like 2 know is what was the reason for doing it like that.frans
Old 04-06-2008, 01:04 AM
  #45
brel
Banned
the Germans built the Tiger 1 with the swing arms facing forward on one side and rearward on the other side, because of the torsion bar suspension
The Tiger I's suspension system consisted of interleaved road wheels mounted on axles attached to torsion bars, along with a drive sprocket and idler wheel over which traveled the track.
The Tiger had a total of 16 torsion bars, with 8 bars running transversely through the hull on each side of the tank, being anchored in a socket type housing on the opposite side. The torsion bars were 5 feet 4.75 inches long (1644.6mm) and either 55 or 58mm in diameter with splined ends. On the outer end of each torsion bar was a swing arm and on the end of each swing arm was the axle. To save space, the swing arms were angled forward on the driver's side and backward on the opposite side.
copied from tiger one information centre http://www.alanhamby.com/suspension.shtml
Old 04-06-2008, 01:15 AM
  #46
1002frans
Thanks Brel
Old 04-06-2008, 03:14 AM
  #47
dave05
dave05's Avatar
the power travels better if it is well lubricated
Old 04-06-2008, 05:43 AM
  #48
1002frans
For info on the k tiger"s suspension go 2 Panzermuseum.com the kt had 9arms each side the tiger 1 only 8 per side
Old 04-06-2008, 05:50 AM
  #49
1002frans
Sorry type in panzermuseum.com.king tiger
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
