King Tiger kit #56004
Old 08-08-2008, 01:45 PM
bowlman
Default King Tiger kit #56004
I got me coming a early King Tiger kit #56004 im looking for a bearing upgrade package for it dont see KT bearing sets out there anyone know if one of the other bearing set will work like the tiger bearing set or one of the others .or even if it needs bearings
thank
jimmy
Old 08-08-2008, 02:25 PM
bowlman
Default RE: King Tiger kit #56004
ok found them at eto they are not like the ball bearings you can buy for the pershing there more of a bushing .
thanks
jimmy
Old 08-08-2008, 03:00 PM
Jeff489
My Feedback: (12)
Early KT (non full option) kits are different than the late kits. The bushing kit on ETO is for late KT's that use two bushings on each roadwheel axle and a removeable hub in the center of the roadwheel. Early KT's only had one bushing, a different shaft, and the center hub is not removeable. I know because I've built both the old and new KT and have had the pleasure of installing the ETO kit in the new KT. The ETO setup might work, for an old style, but I'd check it thoroughly.
I upgraded the bushings to bearings on the older style KT however. I did some research using the Boca Bearings website and identified the bearings I wanted. They were 4mm (inside diameter) by 8mm (outside diameter) and just over 3mm thick. You should measure the bushings to be certain though. Using these measurements, I bought the bearings off the infamous online auction site for about $1.50 US ea. (18 bearings in all). Do yourself favor and get one extra for the inevitable screwup.
I'm pretty happy with it, and they turn very smoothly.
Good luck!
Old 08-08-2008, 03:12 PM
bowlman
Thanks Jeff ill make shore I measure the bushings to replace with ball bearings ive got a mic at work I can use .
got a video on this old beast watch the ending this thing moves . http://video.aol.com/video-detail/ki...004/1276458403
thanks
jimmy
Old 08-12-2008, 08:10 PM
bowlman
Ok I got the early King Tiger kit today alot of the parts look the same as the later model but you can tell its a older kit .
Will have to upgrade the motor to two gear boxes and the turret motor and add elevation with aluminum main gun .
Who else has upgraded this tank and what have you found that works from the later model upgrades .
Jimmy
Old 08-13-2008, 02:53 PM
bowlman
I emailed ETO on the Impact suspension upgrade for the KT and they said it will work just have to relocate the turret traverse if I plan on still using it .
I ordered the aluminum gun barrel and L & R fenders from AAF Tank Museum also .
thanks
jimmy
Old 08-13-2008, 03:04 PM
Jeff489
My Feedback: (12)
Jimmy,
FYI, one of the guys from DAK (our tank club in Phoenix) who posts as "Count Chocula" on RCU has an older style KT just like yours that he is upgrading to a full option battle tank. If you need any tips on how to upgrade the turret traverse, just look him up and PM him. You can tell him Jeff from DAK told you about him, we know each other pretty well. His KT was pretty fast too. I remember he could drive it up shallow hills and actually get some air. I saw your video, and the KT is looking good!
Old 08-13-2008, 03:26 PM
bowlman
Thanks Jeff
ive been debating to keep the old traverse or not and sorry but the video was one I found by googling my KT is still in the box im doing the planning stage at this time on what todo to it and how ive got a list on the upgrades im writing up as I find them like the suspension from ETO and gun barrel and some of the mounting parts for the barrel ill have to order from tamyia . I seen a post from Willy Lower on changing to impact drives to get scale speed and power it wont be as fast as the one in the video but it will last longer from the battle hits .
Jimmy
Old 08-13-2008, 03:51 PM
Jeff489
My Feedback: (12)
Jimmy,
If you need parts, just pm me with what you need. I'm finishing a scratch Jagditger project and cannibalized a full option KT to do it. I used the DMD and MF units, but I've tons of spare parts and I'd sell them for less than Tamiya.
Old 08-13-2008, 04:00 PM
bowlman
Thanks Jeff .
jimmy
Old 08-15-2008, 10:17 PM
bowlman
Ive seen some KT with the Porsche turret did Tamiya make a replacment part of this turret and are they still out there and not have to buy the whole kit or did some one make a aftermarket replacement turret other then Tamiya and is it still out there to buy .
thanks
jimmy
Old 08-16-2008, 02:36 AM
FireflyKeith
Im sure someone will correct me if im wrong but i think Tamiya only put the Porsche turret on the static model, as for after market versions i have never seen one. I have recently brought a 56004 KT myself (secondhand) with lots of bits missing so i have spent a fair bit of time serching for parts
Old 08-16-2008, 10:01 AM
bowlman
Mine has some parts missing also some of the metal bag is not there even the torsion bars were gone but ive got the upgrade for the suspension coming from etoarmor there is a porsche turret kit for sale on the bay for $500.00 and something but its only works off two channel control dmd and no dmdmf unit you can buy a henschel version for around $600.00 so no thanks just want the turret .
thanks
jimmy
Old 08-16-2008, 10:25 AM
chilipiper
chilipiper's Avatar
Tamiya did put out at least one RC Porsche turret King Tiger; Kit [link=http://www.tamiyausa.com/product/item.php?product-id=56007]#56007[/link]
Altough this kit has been discontinued, they can still be found on Evil-Bay; I picked one up a few months ago.
Old 08-16-2008, 10:32 AM
bowlman
yep seen one last night on the evil-bay the guy wants over $500.00 for it im just looking for a turret would buy it but then there go's the cash to finish the Kt I got and other projects.
thanks
jimmy
Old 08-16-2008, 05:49 PM
bowlman
Well looks like im sticking with the Henschel turret there are not any Porsche turrets out there to buy just old kits for over $600.00 with shipping no thanks .
Jimmy
Old 11-08-2016, 08:53 PM
Whitelitenin 38 kv
Whitelitenin 38 kv's Avatar
Default Parting out
Watch next week on E-Bay I'm parting out aTamiya KT I'm keeping the chassis and drive. The rest is in nice shape considering it over 30 years old. It's the old one #56004
