Help! Somebody ID this board..............
1 Attachment(s)
I don't know exactly what this circuit board is for ......[sm=confused.gif]
I'm sure it's a Henglong board since it was in the same bag as an RX14 board. I don't see it on their spare parts photos. What does it do? Somebody please educate me. |
RE: Help! Somebody ID this board..............
Hi Rex,
That's the receiver board for the Heng Long tanks. It goes on the tank and was used fo the TK-RX13 and 14 boards, maybe others. |
Yes, that is the Heng Long receiver board which is also used with the RX18 ESC. It seems to be missing the channel crystal and the antenna wire (soldered on the back). It might be okay if the variable inductors haven't been touched.
ORIGINAL: HondoBob Yes, that is the Heng Long receiver board which is also used with the RX18 ESC. It seems to be missing the channel crystal and the antenna wire (soldered on the back). It might be okay if the variable inductors haven't been touched. I thank you both for the info. |
| All times are GMT -8. The time now is 09:12 PM. |
