question about metal track
Does any one know that Matomart's metal track (matomart.com/prodview.php) will fit Asiatam's late tiger metal wheels or not?
I just get my late pattern wheels from Asiatam and find out that the HL's original metal early tracks do not fit my late wheels. |
RE: question about metal track
Negative. I have that set and went through a lot oftrouble getting tracks to fit the guidehorns. Mato tracks, which I have will not fit and will bind up causing wheels to come off and poosibly breaking things.
ETO armor has the tracks you need. They fit the Asiatam late wheels. |
I got the new black painted ones from rctankwars.com which I believe are the mato ones and they fit better then the regular metal ones I got when I got the tank, I also have the late asiatam wheels and the metal hull, if you have the older metal drive and idlers you want to get the new ones that come with the bushings now.
ORIGINAL: yellowshaker Negative. I have that set and went through a lot oftrouble getting tracks to fit the guidehorns. Mato tracks, which I have will not fit and will bind up causing wheels to come off and poosibly breaking things. ETO armor has the tracks you need. They fit the Asiatam late wheels. |
1 Attachment(s)
Yes, those are the ones I use on mine.It has the asiatam hull, road wheels 3:1 gear reduction and 480 motors powered by elmod. These tracks fit perfectly and do not bind up. Only thing I forgot to mention in the earlier post is I needed to change over to Tamiya sprockets due to a difference in the pitch. I am not sure if it was just mine or not but my sprockets did not work correctly.I purchased a set of Tiger 1 sprockets and installed them. No problems with this cat any more!
ORIGINAL: pangpang_man ORIGINAL: yellowshaker Negative. I have that set and went through a lot oftrouble getting tracks to fit the guidehorns. Mato tracks, which I have will not fit and will bind up causing wheels to come off and poosibly breaking things. ETO armor has the tracks you need. They fit the Asiatam late wheels. |
I'm looking for Tamiya tiger I sprockets.
Is this set I need? But, where I can find only the sprockets? http://imgs.inkfrog.com/pix/jr-rc/102121.jpg |
aaftankmuseum.com
You have to get tamiya sprockets for the tracks to fit correctly. |
