Smoke fluid
Hi Guys,
What seems to be the best fluid for HE tanks with the progressive smoker? Harle |
RE: Smoke fluid
Prop smoker runs off of the same smoke oil,, a little trick to help them last longer is a few mils of 2 stroke oil, every once in a while not every fill. But then you don't want to run your smoker inside if you go that route, or your breathing in some bad residue... The Blitz |
| All times are GMT -8. The time now is 10:07 PM. |
