RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Tamiya gear boxes (https://www.rcuniverse.com/forum/rc-tanks-369/10496823-tamiya-gear-boxes.html)
tomhugill 05-02-2011 08:07 AM
Tamiya gear boxes
Does anyone know if all the tamiya gear boxes use the same gear sets, Ive seen some cheap tamiya sherman boxes on ebay and was looking to use them for spare gears for my KT</p>
sevoblast 05-02-2011 08:35 AM
RE: Tamiya gear boxes
Photo please. There are three types of standard TU's, and then another for Pershing. First off, black covers on them?
tomhugill 05-02-2011 08:38 AM
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=230613177680I belive these are the most recent TUfrom tamiya
sevoblast 05-02-2011 08:47 AM
OK, for starters he says he will not send out of UK. You may be able to deal with him, but I doubt it.
Second thing. There are two types of that Tamiya Transmission as far as gears to. The Type 2, which was not out long, has black plastic gears near the motor, under the cover. The Type 3, which looks the same from outside, has metal gears there. Other differences is the final output shaft length, shortest is Sherman, KT and Tiger 1 is about 2mm longer, and Panther is way longer.
Yes, the gears will fit all Type 2 and Type 3 transmissions, but without seeing the rearmost gears under the black cover, I can not give you a definite as to which it is.
tomhugill 05-02-2011 08:53 AM
Thanks for your help servo, Im living in the UK so that is no problem for me also Im after the individual gears to rebuild the boxes Ialready haverather than seaking to drop the full tranny in like for like.
sevoblast 05-02-2011 09:51 AM
I'm so tired tonight I missed your HOR. Got for it, good price as long as they are in good condition. It's mainly the front gears that get worn, and they should drop in if memory serves.
